Spawn300Z
You can always get a protective bag
Won't it damage the HPs if they get hit or something?You can always get a protective bag
I meant what protective bag you use for the Lirics themselvesI just sold mine. But yy backpack fit their carry case. But if I take two headphones I put in a protective bag to prevent scratches and place them in the compartment. I have The Tumi Alpha Bravo Esports Backpack Tumi Backpack. This one is high. But gives you an idea what mine looks like.
There are a lot of esports backpacks out there. These backpacks are specifically geared for gamers to bring their equipment on the go with them. It will work for audiophiles also. If you want to use any regular backpack keep using your case.
Now you've made your decision the only thing left to do is enjoy themHad been swinging back and forth between E3 and Liric II, I finally ordered Liric II.
After reading and watching many reviews and comparisons of the two, since I can’t hear either,
I chose base on the better looking and construction of Liric II.
E3 might have patented new tech, but it looks bad to me.
I'll run a test for yaDoes liric 2 take a large sub bass shelf well? Looking for an “upgrade” to my kennerton gjallahorn gh50s and these seem intriguing if they can transform into bass monsters with a 12 dB shelf at 20 hz via Loki and some good juice (Jot 2).
Thank you much!I'll run a test for ya
Any updates here? Interestingly, I just came across some info on the DCA E3 forum that those clip and distort with ifi xbass on. That makes them a total deal breaker for me, really hoping the liric 2 driver is more capable of playing subbass loud. I’m finding that a lot of high-end headphones seem to have this fatal flaw unfortunately.I'll run a test for ya
I'm not a bass head but how deep does a plucked double bass go. My audition track for bass is off Jennifer Warnes' SACD Another Time, Another Place with track 2 being the tester. It opens with a plucked double bass and the Liric 2 handles it supremely well. The note and the decay is detailed and deep.Any updates here? Interestingly, I just came across some info on the DCA E3 forum that those clip and distort with ifi xbass on. That makes them a total deal breaker for me, really hoping the liric 2 driver is more capable of playing subbass loud. I’m finding that a lot of high-end headphones seem to have this fatal flaw unfortunately.
Sort of narrowed down my upgrade path to:
Zmf atrium or caldera closed
Liric 2
Kennerton Rognir p or Arkona
Would really love to save some $$$ though if the liric 2 can turn into a bass monster, maybe similar to what I’ve read about the LCD-4.
Thanks!
The op asking the question wants to add a 12db bass shelf at 20hz ... Why is beyond my understanding but in my experience almost anything will clip have distortion with that much of an increase.... But what do I knowI'm not a bass head but how deep does a plucked double bass go. My audition track for bass is off Jennifer Warnes' SACD Another Time, Another Place with track 2 being the tester. It opens with a plucked double bass and the Liric 2 handles it supremely well. The note and the decay is detailed and deep.
