MDR-EX1000 cable replacement
Jul 22, 2018 at 3:36 PM Post #61 of 72
Thank you for the helpful reply. It seems the best course is to try to find an OEM ex1000 cable (if I can) and have it Re-terminated. Would I have to go to Sony or do any third parties you know of sell oem cables? Thanks.
That’s exactly what I did! I bought a stock cable on Ebay (make sure you get the long and not short cable). The long cable is around $80 on eBay. Then I ordered a Pentaconn right angle 4.4 adapter from Japan using an agents. Once I received both, I sent them to Plussound and they reterminate the cable for an extremely reasonable fee and it was done in a week and a half! Workmanship is spot on and now the EX1000 sound a bit tighter when using the balanced output of the ZX300!
Jan 25, 2019 at 12:36 AM Post #62 of 72
Just thought I'd update on this TaoBao adapter that works on the EX1000 !
( I also enquired at e4ua.jp, and it was around USD165 total. So I decided to try the TaoBao one first, as kms108 had reported that they worked on his EX600.)
https://item.taobao.com/item.htm?sp...ri0Lj6&id=550439102928&ns=1&abbucket=6#detail
Found a picture of the brass one.
Just got the brass one, EXK-MMCX. (not the resin one in the picture) It's the more expensive one you get when selecting the 7n option, for CNY366.00 (US$56.00). The adapter is so small, it fits inside the EX1000 socket, and you just see the faceplate/MMCX showing above the collar.
The description on the web site is: copper thread, 4n silver pin(regular) or 7n silver pin optional. The socket (MMCX?) uses 4n sterling silver pins, silver solder.
This adapter fits the EX1000. The right side went in smoothly, the left side had to fiddle with it a bit, and was a little tighter, but went in OK. Am listening to the EXK through a Dita Truth cable, awesome interchangeable plug system, with a 4.4mm plug to the Sony WM1Z. Very nice.
Now that I know they fit, I will order an EXK-CM adapter, and that will allow me to use any of the cables I have, which are either MMCX or CM
Another adapter, that does NOT fit the EX1000:
https://world.taobao.com/item/554630802940.htm?fromSite=main&spm=a21m2.8232368.0.0.14e47277HpbkP3
CNY189.00 (USD29.00) ( Company name Gongsakura )
Got this one also, while a friend was helping me to order from TaoBao. DOES NOT FIT THE EX1000 !!!
These would not fit the EX1000, I tried a small amount of force, and stopped, as was afraid of damaging the EX1000 socket or collar. Might fit the EX800/600, as I believe they take a slightly wider (at the tip) plug. Don't know, though, as I do not have either to try. I may try to file the plug contacts down, as I think they are too thick, which is why they do not go into the EX1000. But no urge at the moment, as I now have a working adapter, which is a better quality than this one. I'll keep it as a reserve.
tried to select the one you bought but nothing happened,
how is yours holding up?
just bought the EX800ST and thought using this adaptor would be a good idea..
Jan 25, 2019 at 12:02 PM Post #63 of 72
Sorry, can't really say, as I have not been using the EX1K steadily with the adapter. I was recently using the EX1K short factory cable with a BT receiver (Fiio BTR3), and have been using my better MMCX cable on other IEMs
Apr 15, 2021 at 1:59 AM Post #64 of 72
I just contacted this person again for a up to date on his adapter, the information below is probably a year ago, further below is the up to date information that I received yesterday.
http://e4ua.jp/?p=2825
4000yen labour cost for each piece, total 8000yen for both Left and Right
5800yen for the EX parts
890yen for the MMCX parts
Total 14690yen (including tax 15865 yen)
This is for the matt black.
Are these adapter still available? How can I have a set made and hipped to USA?
Thanks
Apr 15, 2021 at 2:48 AM Post #65 of 72
Thanks
Use the link, and send a message, he accepts worldwide order, and you pay by PayPal.
If you have access to taobao.cn, they have a cheaper one less than 30usd, quality not up to the Japanese one, but does the job.
Apr 15, 2021 at 2:53 AM Post #66 of 72
latest price.
This is a example of the price back in November 2020
This is the most up to date on his set price.
4500 yen labour cost for each piece, total 9000 yen for both Left and Right
6200 for the EX parts
780 yen for the MMCX parts
Total 15980yen (including tax 17578 yen)
Optional cost
Glossy finish + 2000yen
Tone adjustment correspondence + 3500 yen (including colors other than black, selection include, white, transparent, clear color and metallic type)
Since the metallic type requires a glossy finish, the production cost combines the above two options,
but only for the MDR-EX1000, a little more dedicated metallic is prepared, so combine it with the glossy buff finish. It is set at +4500 yen
Shipping will be handled only by EMS in case of overseas shipping, shipping fee will vary depending on the area of residence. In addition, from 1500 yen is separately paid as a packing / shipping fee.
We accept your quotation and enter the production queue by depositing via PayPal. Please note that payment with PayPal will cost 4% commission.
The total amount you will pay is "(Product fee + EMS shipping + packing · shipping fee) xPayPal payment commission 4%".
Apr 15, 2021 at 2:55 AM Post #67 of 72
Remember to send a photo of the item u want.
Apr 16, 2021 at 6:50 PM Post #69 of 72
Now only 10 use.
Apr 16, 2021 at 6:54 PM Post #70 of 72
Wrong photo, this is the correct one at usd 21
Apr 17, 2021 at 12:04 AM Post #72 of 72
Taobao.cn or aliexpress, although aliexpress is slightly or expensive.
