Jan 30, 2010 at 10:17 PM Post #886 of 2,660
Hello. Anyone from Europe has imported the Maverick?
I don't have a lot of experience importing and I would hate to have to pay customs since my budged is already at the limit here. I take it there aren't any European's vendors right?
Anyway I will make the purchase next month so I'm still looking at various amp/dacs.
Jan 31, 2010 at 1:46 AM Post #887 of 2,660
Just want to confirm that the OPAMP furthest from the tube is the one used for the headphone output.
Correct?
Also did anyone have any trouble removing said OPAMP? I went to replace mine and found that one leg was somehow stuck. I can't see how one particular leg could be stuck like this. Since it had to be smoothly inserting into the socket in the first place.
Anyhow since the other pins eventually started to bend I had no choice but pull the OPAMP out. Thankfully the only thing that broke was the pin and a small piece seems to be stuck in the hole.
Thankfully the new OPAMP went in and works (assuming the answer to my first questions is affirmative.); but that leg will never go into as far as the other ones since the hole is partly blocked.
Sounds good though
Jan 31, 2010 at 2:10 AM Post #888 of 2,660
Correct?
Sounds good though
To your question, yes the furthest one from the tube is the headphone opamp. The legs of the LF353N's that are installed seem to have been handled with pliers or something. Mine were kinda dinged and bent and it took a little more force than what I was comfortable with but I didn't care too much since I had several replacements
I used needle-nosed pliers to pull mine out. Good to hear yours works even after the little mishap.
Jan 31, 2010 at 2:17 AM Post #889 of 2,660
I kinda wondered if the original OPAMPs had been first inserted into the sockets and then sockets soldered on the board. Maybe a little solder flowed into the leg.
As long as it works I'll try not touch it or look at it funny lest I mess things up
Jan 31, 2010 at 2:39 AM Post #890 of 2,660
Jan 31, 2010 at 2:52 AM Post #891 of 2,660
Originally Posted by _Spanky_ /img/forum/go_quote.gif
You bring up a good point, I hadn't thought of that. I'm thinking now that the opamps were soldered directly onto the board, desoldered, socket installed and then put into the socket.
You are right. They are soldered onto the board first ( original design is to have OpAmp soldered to the PCB directly). I changed my mind later to have socket installed, therefore, have to take the OpAmp from the board and install the socket.
Jan 31, 2010 at 3:46 AM Post #893 of 2,660
_Spanky_;6361840 said:
You bring up a good point, I hadn't thought of that. I'm thinking now that the opamps were soldered directly onto the board, desoldered, socket installed and then put into the socket. In fact, I'm inspired to take pictures:
Your guess was better than mine so I guess you get the prize!
Jan 31, 2010 at 4:50 AM Post #894 of 2,660
Booyah!
Is this extra step going to be removed in the newer batches? i.e. socket soldered first?
Sure, once we have used all the stock PCB board
Jan 31, 2010 at 10:31 AM Post #895 of 2,660
Ryan, I don't think it's necessary to open a support ticket and a public answer would be cool as well, have you thought about offering a opamp-upgraded version like the tube-upgraded one? I think the LT1364 and LM4562 is a well-liked combo. I would imagine being in China that it might be harder to get ahold of those. But there's people that would want that but wouldn't want to open the D1.
Jan 31, 2010 at 10:35 AM Post #896 of 2,660
Originally Posted by asianfi /img/forum/go_quote.gif
I think the main difference you'll see (when I had my 700s) is the bass response. Whilst the 700s are bass anemic they really come out of their shell with the SSD out. You'll also notice a small extension in the SS.
Through tube preamp to my TA15 or AMP the 700s sounded a lot warmer, and the bass was well rounded and punchier.
Do you think if I tubed out to a 3.5mm it would sound good?
Jan 31, 2010 at 12:26 PM Post #897 of 2,660
Out of curiosity is there any way to properly use the tube output with headphones? Like through an amp or something without burning out your cans as mentioned previously in this thread. I just want to hear the contrast in sound more for fun than use.
Jan 31, 2010 at 3:51 PM Post #898 of 2,660
imported and piad 18 euros customs to DHL.
tested a couple of different opamps and found AD8599 for analog out and 627BP for headphone amp sound a lot better than stock ones.
Jan 31, 2010 at 4:21 PM Post #899 of 2,660
I run my Maverick into an integrated amplifier from the tube out, mostly to run my speakers. But sometimes I use headphones through my integrated's headphone amp. Works very well, and I can definitely hear the difference from the Maverick's own (un-tubed) headphone amp.
Jan 31, 2010 at 4:29 PM Post #900 of 2,660
i expect to add 40% in tax and postal handling fee, or if i get lucky ZERO..
