Wow, cool. Thanks. I guess that answers the heat question sufficiently.
Now to the REAL troubleshooting..........
Having now plugged it in and played with it, I have to say I'm a bit disappointed!!
I seem to have an annoying and constantly present static /clicking noise.
It's audible at reasonable listening levels and is akin to ...well, static! It sounds like all my music is on dirty vinyl
I have tried both standard and tube out's and have entirely disconnected external kit and used the headphone jack and still I get this HORRIBLE clicking sound.
I've tried different power cords and passed it through a mains conditioner - still the same!
The way I see it, I've eliminated the outputs (as it's there on headphones too), I've eliminated the tube (headphones don't pass the tube do they?).
It's there on optical and USB, interestingly if I line-in from the laptop, it's gone.
EDIT: As I write, I've tried a different optical cable and that's fixed it for both optical and USB?! Weird.
I've had it on for maybe an hour - I never got the opportunity to try the original tube and opamp for the DAC as I swapped them straight away!
I use a Harman Kardon AV Receiver (UK AVR255 / US AVR254) and I have to say it's requiring quite critical listening to determine how much better the D1 is over the inbuilt DAC of the Receiver. I think the tube output is definitely richer and more rounded, but also a little brighter than the inbuilt DAC - this may be the analogue stages on the receiver rather than either DAC.
I'm not going to say I'm disappointed, but I'm certainly not blown-away in the way I use it at present. I'm going to keep burning-in the unit/tube and see if my perception/experience changes much in the next few weeks. I may also swap out the tube again. At present I've got a Russian 6H3NE tube in that's been cryogenically frozen which according to the seller makes it sound close to a $250 Bendix
http://cgi.ebay.co.uk/CRYO-SUPER-LIFE-6N3P-E-Hi-Fi-AUDIO-TUBE-2C51-5670-/300353336777?pt=UK_Consumer_VintageAudio_RL&hash=item45ee7435c9#ht_4674wt_1334
I also have a couple of 'vintage' 5670's on their way which I may try out .... if one or more of the 5670's are 'duff' will it damage the D1 at all? Or will it just fail to work?
I've replaced the opamp nearest the DAC with a LM4562NA.
Luckily I can send the same audio (courtesy of Apple Airport Express's) to different inputs on my Receiver and switch between them so I only lose 1/2 second of audio in the process which means I can listen for discernable audible differences. I think the D1 inches ahead on being more dynamic/open at this stage, but I think in tightening up the midrange and bass it also can sound less 'full' at the bottom end. A good example would be that a bit of piano on the Receivers DAC sounds quite 'mellow' whereas the D1 is more dynamic but with it loses some of the mellow in favour of clarity - which is possibly a good thing! - I just need to get a little more used to it maybe?
I don't know if anyone has any suggestions at this stage on how to get a more mellow sound out of the D1, or whether my ears and perception will adjust to the new dynamics, but I guess I need to let the unit settle in a little more first. Should the D1 itself as a unit need burn in time, or just the tube?
Thanks again all..... I'll post updates....
