- Nov 19, 2016
Had mine for several months now and Im still amazed with the sound. Hopefully though they come out with a version that has a balanced hp output.
Matrix has a new Mini-i driver (3.40) for anyone who has experienced issues with Windows 10 after installing the Microsoft Anniversary Update.
You can download it here from our site. Anyone with the Anniversary Update please report your findings. This should fix any problems some have experienced.
Have you checked if the fuse is still intact?I've had a Matrix Mini-I v.1.82 for a couple of years, and I've been really happy with it, but...
... a while ago, a weird problem with the display appeared. Upon power up the display worked ok, but after a while it showed just gibberish. Took the thing apart, and some of the electrolytic capacitors had swollen, though not leaked.
Now the unit won't react at all. When I flip the power switch, nothing. If I press the volume knob, still nothing. I have already replaced the faulty caps to no avail.
I'm looking for some good advice on where to start looking for the problem. Can anyone help?
Huh. That's a tough one. Sorry can't help much.
That's exactly what I did. The +12V and -12V regulators were standard L7812CV and L7912CV which I luckily had in my stock from another project. Those weren't necessarily faulty, however. It seems they don't get input unless the whole unit powers on. The +-18V from the transformer is routed to the regulators through a relay near the TRS jack. Probably a power saving feature.Well, maybe the regulators are faulty? Try and replace the regulators. Are there markings or anything on them?
