Hellenback
- Apr 15, 2007
The following link might help you..
http://www.headfonia.com/matrix-mini-i-balanced-dac/
Thanks
I've seen it. I'm looking for members' impressions.
Hi Guys,
How does the Matrix Mini-I as a DAC compare to the Musiland Monitor 02 & Essence ST (pure sound quality only)?
Basically I'm wanting to get the best source around this price range (willing to spend more for the Mini-I if it offers the best SQ)!
Going to connect it to a Matrix M-Stage (for headphones) + Swans T200B speakers (XLR balanced).
If you're running anything balanced I can't see how the other DACs you've mentioned would compete with the Matrix Mini-i as it's the only balanced source. Also, it uses the same chip as the Cambridge 840-C CD player which is very highly regarded and fairly expensive at > $1000
Others use some of the Monitor line of products for 24/192 usb->spdif conversion.
Just received my Matrix Mini-i and WOW!.....this is an exceptional little DAC. Running a balanced pair of Senn 650s, single ended AKG-240 (MKIIs) and coax out to the stereo....talk about convenient for anything. I'd have gladly paid what it cost just for the DAC section of this little powerhouse.
Took a quick listen to the headphone out and it's a real headphone amp, not just an afterthought. If I didn't already have the MKVII+ I'd listen to this on it's own for awhile....problem is the balanced out to the MKVII+ sounds too good to go unused for long![]()
I'm going to give it a few days and see how it settles in before saying too much, but right out of the box it's already very easy on the ears. Another member/friend and I are going to put the LD DAC_I, the Matrix Mini-i and the DacMagic up against each other as soon as we can get together. I'll be sure to post impressions when it happens...likely in the next week or two.
Gotta go listen to some music!
@sunneebear...thanks for the heads up on this one.
Interesting impressions. Are you saying that you ran your balanced HD650 right out of the back of the Mini-i?
Anyways looking forward to the results of your three-way balanced DAC shootout![]()
Well you have given me an idea, I will try my HD600 with a dual XLR cable out of the back of the Mini-i sometime. It has great synergy from the SE jack in front, so it will be interesting to see what happens.
I can't imagine why that would work as the output would be too low. The Matrix's headphone out comes from an internal amplifier which I doubt is engaged through the XLR connections.. Sorry if I inadvertently gave you the wrong impression.
I see your point that it may just be an attenuated line out![]()
