Correct me if i'm wrong but the dither option in the matrix dac is turned off when sending DSD right?
Matrix Audio X-Sabre Pro
- Thread starter mtoc
I just read on the denafrips terminator thread that they don't recommend plugging in both xlr and rca plugs into the dac at the same time. Does the same go for the x-sabre pro?
omniweltall
- Nov 13, 2016
Is fine with Sabre Pro.
Does anyone use Roon with matrix x-sabre pro?
Seems like the dac doesn't like having DSPs added to the chain.. When I add a convolution file, or even parametric eq, either the song doesn't play and I get the message that the dac failed to initialize, or one or two songs play and then subsequent songs suddenly fail (and then failed to initialize msg pops up).
Once I take away the DSPs, the songs play as per normal.
For anyone playing DSD, or converting to DSD, did you find that the sound was better directly into the USB port, or better via XSPDIF2 i2s if you have one?
I find IIS into the Matrix using PC --> Singxer SU-1 --> DAC has a blacker background and more detail, while still being very engaging and musical. This is with HQPlayer software either outputting direct DSD source or converting PCM --> DSD.
Hmm i find the sound to be kind of less exciting going through my Shanti lps > usbridge signature > idefender > xspdif2 i2s > matrix sabre pro than directly connecting it to the Allo streamer technically I think a direct connection will give the lowest jitter as DSD is more sensitive to it than PCM.I find IIS into the Matrix using PC --> Singxer SU-1 --> DAC has a blacker background and more detail, while still being very engaging and musical. This is with HQPlayer software either outputting direct DSD source or converting PCM --> DSD.
Baten
- Sep 13, 2012
Sometimes less is moreHmm i find the sound to be kind of less exciting going through my Shanti lps > usbridge signature > idefender > xspdif2 i2s > matrix sabre pro than directly connecting it to the Allo streamer technically I think a direct connection will give the lowest jitter as DSD is more sensitive to it than PCM.
Yeah the thing the i2s output has going for it is the galvanic isolation that matrix audio says they deploy, which is probably not needed depending on how clean the usb port used is from EMI/RFI common mode noise, data line noise etc.Sometimes less is more
It's probably possible for the jitter to be lower via the i2s but we won't know for sure without measurements.
On another note i don't get why more usb converters don't use the NDK SDA clocks, their close-in phase noise at 10hz is lower than the crystek clocks at around -105 to 115dbc.
Agreed, but the key word is "sometimes". Ultimately, listening tests and subjective preference factor in, explaining why reasonable people may differ in their conclusions.Sometimes less is more
Did you try EQ with another DAC?
Would consider the issue in Roon.
Is your PC fast enough to handle EQ?
Yep I have done EQ with another dac (benchmark dac3b) and no issues. PC is Intel 8th gen core i7 2.7GHz with 32gb ram.
Ok.
How are your DAC's connected to Roon?
PC(core, bridge) - usb - DAC?
PC(core) - roon bridge -?? - DAC?
Is the roon signal path different between the dacs (different conversion, etc) ? Or the speed factor?
Ok.
I have two setups.
Qnap Nas (core)
Network switch
PC (bridge)
Dac (matrix audio mqa x-sabre pro)
Qnap nas (core)
Network switch
Cambridge audio cxn v2
Dac (benchmark dac3b)
Not sure what you mean by speed factor..
I can live without adding dsp to the first setup, just that it would be nice if I could, to just do a parametric eq to reduce gain a bit at about 2khz for when I listen with headphones.
I have two setups.
Qnap Nas (core)
Network switch
PC (bridge)
Qnap nas (core)
Network switch
Are the following assumptions correct: The benchmark is connected to the Cambridge with S/PDIF (coax or toslink). The Cambridge seems not to be directly roon ready, but you can connect via Built-In Chromecast, which is limited to 24Bit/96kHz?
If correct: Have you tried to connect the matrix via S/PDIF to the Cambridge? I'm pretty sure, it will work incl. EQ.
Are the next assumptions correct as well: The matrix is connected to the PC via USB? The PC runs Roons Bridge only, not the core?
If correct: USB connections allow higher sample rates, then Chromecast. Higher sample rate, higher compute requirements. Your i7 PC has quite good specs, but it doesn't matter as the DSP/EQ calculations are done in the roon core. Not sure about the qnap NAS spec, but if have the normal version for home use, it not compareable with the compute power of your PC.
Depending on the complexity of your EQ and other conversion, you NAS maid be not fast enough. You can check your signal path. On top of it there should be "Performance/Speed factor" like "8.3x" or any other number. If this factor is close to 1.0x it means your nas is to slow. Please note, this factor is not stable, but change depending on the load of your nas.
Another potential problem could you the USB driver from matrix, especially for very high sample rates.
