oqvist
- Oct 28, 2004
If you liked the v200 go with that. THX 789 dont sound the same so its a gamble.
This item has become a massdrop made ready stock item so you don't have to worry about the shipping time as long as you are inside the US. I bought one through a friend in the US on 24th November, Received on 2nd December.Dear All,
Also, I've read about long waiting lines but the Massdrop site says there' available for direct purchase. Can I receive it this December?
Thank you in advance.
Dear All,
I was planning to buy Violectric V200 (well, frankly speaking, it's Chinese clone), but upon noticing this amp from THX I'm wondering if I should lean toward this one. The problem is that V200 I have listened with my ears and this one I only read reports on the web. Is it worth going to THX 789 over V200 if I will be listening to it thought HE400i headphones? The source will be a portable DAC for now (Opus 1s).
I know nothing about the V200, but I do have 2 THX AAA 789s. Really like the amp, flexible, nice design and the sound seems to be very accurate compared to the source. Massdrop should have these in stock, but if you absolutely want it in December I'd order it with expedited shipping and then mentally prepare yourself for failure. Massdrop is not known for outstanding shipping speeds.
V200 is more expensive, more difficult to order and has no balanced output (as well as pass through one). Are they so different in the signature? In what way, can you describe?
V200 is a bit v-shaped I delta and THX 789 dont to
Sounds like you are working towards getting the THX AAA 789. The amp must have the features you need of course. Do you need balanced output or pass through it´s a given not to go with the V200.
Long time since I had the V200 it had more of a v-shaped signature I felt but will not go into details more then it really does have a clear signature. And if you really liked it it may suit you better. Of course the only way to know is to get one and compare
Buying original Violectric is out of scope due to its price for me. Having balanced is not a critical thing but I would like to do it to have maximum power to my 400i. Having pre-amp option is a benefit for the future mostly, so not critical.
Thank you for your information on shipping. My friend is going to my country only in January, so no problem with him receiving it after holidays. Why would you need two of them, btw? )
Received mine. I don't have much impression other than it's a solid SS amp that seems way too good for its price. Compare to my SPL Phonitor, the only thing that I noticed it's FAST. It does imaging slightly differently. This little thing is easily matching my SPL in power and clarity.
Pros:
- drive THREE headphones at the same time as long as you are not exceeding the electrical capabilities of the amp. Do your own math before you plug in three ultra-low impedance headphones: 1/Rtotal = 1/R1 + 1/R2 + 1/R3
- Line pass-through without powering the amp on
- black background. should be fine for your IEMs
Cons:
- Volume pot does not go completely silent
- Super low volume has channel imbalance
- Gain1 position has a crosstalk issue. Probably not audible in most cases, but people have noticed it.
Do you mean that when turning the volume all the way down that you can still hear audio playing? Also what is crosstalk? I've seen some people mention that the SE headphone jack is not very powerful compared to balanced? I have an Aune X7S and for now I'm using the SE for my headphones. With my HD6XX I have it on low gain with the volume knob at just shy of 12 noon. That's plenty loud for me.
