To be honest, I don't really use my O2 amp. Mainly because the AE-5 is superior headphone amp than the O2 I have here at least. AE-5 headphone amp has >10 dBA advantage in dynamic range, >7 dBA in noise level and >11 dB in stereo cross talk. In reality the difference is likely even larger because the AE-5 hits the ADC (SoundCore3D) limits (102dB) in dynamic range and noise level. Those differences are so large that one can instantly hear the difference. Not surprised at all why you think that O2 sounds thing - I think so too and it's probably thanks to that dynamic range. Soundstage in neutered by stereo crosstalk.While I haven't heard a SB AE-5 the O2 is one amp that I really didn't care for since it was the cause of sibilance along with a fairly dry thin sound with most of the headphones that I had at the time I had the O2/ODAC. I'd suggest getting a hybrid amp (tube in the driver stage and SS for the power stage) if you are sensitive to sibilance since most tube amps usually reduce sibilance to some degree and can be fine tuned with different tubes. One suggestion is the LittleDot 1+, fairly cheap but also flexible in tubes and op amps of if you have a little more to spend an Ember is a very good amp for the price and can use a wide range of tubes. I don't know how hard it would be to get an Ember in Finland but if you are able to get one I think it will do wonders with almost any headphone that you have or are considering.
It's very neutral and pleasant sounding amp (I'd say smooth but detailed) with excellent dynamic range and channel separation (thanks to individually amped channels). Mostly probably thanks to the Sabre DAC.
