Massdrop x Liquid Carbon X Discussion
post-15338172
Post #421 of 455
eeagle
FL, Space Coast
FL, Space Coast
I can only assume the CTH has a similar Cavalli signature to the LCX which I do have, in which case i would guess you would not be gaining much. I personally chose the LCX over the CTH because I don't like to maintain tubes or let them warm up, not to mention they must always be on top of the stack of multiple boxes. I do have the 789 which is great for hard to drive HPs, but I far prefer the LCX sound signature and use it often. I too have the R2R which smooths about any amp out to my liking. You have selected some great equipment, enjoy the music.
post-15338229
Post #422 of 455
Shane D
Halifax, NS
Halifax, NS
I would second eeagle's recommendation. You already have the Cavalli sound, so I wouldn't add unless it was something different. I have two Cavalli amps, but only because I was curious how good a $100.00 (actually $80.00 for an open box) amp could be.
If I were you and went for a third amp, I would look for a different sound signature. Variety is awesome.
Shane D
post-15338595
Post #423 of 455
buke9
Help and Recommendation Contributor
Kentucky
Kentucky
The CTH and LC (have the first run original not LCX) are quite different in sound the CTH is actually a bit brighter sounding than the LC and does not have that liquid warmth that I like so much but the CTH is a very good amp for the money though and I like it quite well with the HD-6XX’s.
post-15338686
Post #424 of 455
PaganDL
Hi @Ninja Theory,
As others have said, best summed up by both @eegale & @buke9, it all depends on you & your preferences.
Just my humble 2 cents, LCX isn't going to add much to what you already have unless you want to add another sound flavour to your audio chain...
On my end, my 789 is on its way so I can't say how it will sit technically along with the CTH & LCX but given CTH is a Tube Hybrid & the other head amps are solid state, as said, different sound flavours, just depends on what you feel you need.
CTH, as a tube amp will definitely give you more colour & certainly if you find a good tube with good synergy for your entire audio chain.
The final point is if your better half is already more than pissed, I would respectfully lay off till a better time...if ever.
The last thing you want to do is make home life hell for no reason (not that I ever experienced that by the way) but why be tempted when it could cause a problem in the first place.
Hope you have a great day !
post-15339172
Post #425 of 455
Ninja Theory
South Africa
South Africa
Thanks guys, great advice all round. I decided to put the LCX on ice (for now). I will buy it in the coming months to satisfy my curiosity. In the meanwhile I bought a Sound Blaster X7 Limited Edition for my gaming setup. I got a great deal on a well loved one year old unit from a friend. Will stay subbed here though, it seems there's plenty love and passion for the LCX here :dt880smile:
I'll also report back on the CTH vs the 789 (when my CTH arrives). For anyone who doesn't have (or hasn't heard) the 789, I must say, I have never before heard an amp that so clearly allows the DAC's characteristics to shine through for what they are. I cannot imagine a setup without it. Highly recommended. And let me add to this... the Airist R2R is an incredible little DAC. I consider it some of the best money (south of $500) that one can spend on a DAC. Double thumbs up recommendation.
Reactions: dbsylvia
post-15372466
Post #426 of 455
lesale08
A place of corrupted and greedy people.
Sorry I am new to this ICs thingy and planning to buy this amp with sdac. My question is, can you actually use the balanced mode if you only connect through the dual rca or choose that mode? Like will it sound? Or balanced can only be used when dual 3 pin xlrs are used?
I am also planning to use this with a dap, wm1a to be exact and am looking at those 3.5mm to dual 3 xlr male and 3.5mm to rca male ICs.
Any help is greatly appreciated.
post-15372663
Post #427 of 455
Shane D
Halifax, NS
Halifax, NS
If you want to hook up your DAP, you will have to buy this cable:
I bought it on Amazon and it shipped from Hong Kong.
Then you can use 1/4" or balanced out. I am not sure that the unit is truly balanced, so I doubt it matters.
Mr. Cavalli did state though that the LCX sounds better XLR out.
My setup is NW-ZX300 DAP to SMSL SU-8 DAC to various amps.
Shane D
Reactions: trellus
post-15372784
Post #428 of 455
lesale08
Shane D
Zx300 has the usb dac function while the wm1 series don’t based on what I am reading previously. Could be wrong as new fw updates may have solved this. Will have to confirm.
thanks for your inputs.
post-15372792
Post #429 of 455
Shane D
Halifax, NS
Halifax, NS
Sorry if I gave you bad advice! So, are you thinking about headphone out via a 3.5mm X 2 RCA cable? If so, you would be bypassing the SDAC, I believe. Maybe just buy the LCX?
Hopefully someone else can pipe in with better advice.:)
Shane D
post-15372803
Post #430 of 455
lesale08
Shane D
I do appreciate the feedback mate. No need to apologize. As I am also not sure as well. :L3000:
That’s what mostly I’m reading on the wm1 thread. And yes I am thinking about using that cable. I also ordered 3.5mm to dual 3-pin xlr.
post-15372821
Post #431 of 455
Shane D
Halifax, NS
Halifax, NS
I tried a 3.5mm to dual XLR to feed a balanced amp, but it didn't work for me. Introduced massive hum into the chain and was not usable. And, again, you will be bypassing the SDAC.
Shane D
Reactions: lesale08
post-15372921
Post #432 of 455
eeagle
FL, Space Coast
FL, Space Coast
@Shan @lesale08 The beauty of the LCX w/SDAC is that the SDAC can be used independently, in fact the LCX doesn't even need to be powered on to use the SDAC for another AMP, it just uses USB power (I use it with my Spark). The LCX does not require a balanced input to provide a balanced output to the 4 pin XLR, the SE input will work fine. However, unlike the 789 the LCX does have two separate internal paths so it should benefit SQ wise, from a balanced DAC input.
post-15373970
Post #433 of 455
lesale08
Thanks for the input. That's interesting. I am currently using the lcx through usb plugged to an old lappy and is working fine.
Will report back once I have the rca and xlr cables.
post-15381990
Post #434 of 455
Shane D
Halifax, NS
Halifax, NS
The LCX is a decent amp for $300.00. It is a great amp for $200.00, which is what I paid.
Today it is on MassDrop for $160.00!! That is a screamin' deal.
Shane D
