armymanhaha
- Apr 5, 2017
Yeah, I think the jitterbug works because it's a filter, not an ADuM based isolator so it's simpler.
Does it work for noise from mouse movements / gpu load?
Every review is about it changing the sound stage and imaging and reducing jitter...
Edit: the jitterbug does limit the HD-DAC1 to 96khz right? (Only use 44.1khz anyway)
Optical also has the advantage of not disappearing from your PC when the DAC is in standby mode or turned off, which is annoying as it's not always on like other standalone low power DACs.
Edit2: The DAC is supposed to have a ground isolator so the filter might be enough? Any ideas?
I haven't encountered any noise from mouse or high load while gaming (4790k @ 4.7ghz 1.3v, GTX 980Ti - yeah old) prior to connecting the Jitterbug so I cannot say if it resolved any noise issues if I havent heard any to begin with. My USB output with the Jitterbug remains the same, I can still send DSD files (2.8M) to the HD-DAC 1 with no issues. I suspect it is your software that is having issues. I use Foobar with DSD plugin.
I'd liek to comment though that through Optical, I was able to hear noise via sensitive IEM and the amp gain @ high and the knob @ 2o'clock. When I switched back to USB, it became silent again. Possibly because my optical comes from directly to the PC's noisy motherboard. I suspect if I use a standalone usb to optical converter it will yield better results - but there's no need because the USB input from Marantz is quite good.
