audionewbi
- Jan 24, 2010
Just wanted to report that TH900 synergy with maratnz is 10/10 for me.
Anybody else having issues with the HD-DAC1 and El Capitan or is it just me?
The sound/midi settings for it changed to 352,8 Hz (which it doesn't support), after changing it back it worked fine.
After running out of battery and the computer turned off it changed back again for some reason, a normal restart doesn't have the same effect thankfully.
Hi, Audionewbi,
I've been meaning to ask you seeing that you are actively following Chord Mojo if you consider it a considerable SQ upgrade over HD-DAC1. I am using HD-DAC1 both as a HP amplifier (Fidelio x2, Grado S325is) and a DAC to a REGA Brio. Portability is not the leading factor for me.
I only use Optical from my Mac, do you guys thing USB is better to be used?
