treecloud
- Mar 20, 2012
Same here. '650's on low gain on my office rig. I'm never over 10:00 for medium office friendly levels.
Wow, I have to use high gain and regularly am at 12:00.
Me too...and even then it's missing some dynamics (on mine). I sent a note to Schiit and see if there is additional troubleshooting I can do. Otherwise I believe they will have to take a look at my amp and see if it is defective.
Something missing in this conversation is system interaction. What is the gain of the device driving the Magni 3? It's a huge variable on loudness of downstream amplification devices. But has little to nothing to do with the power capacity of that device. Impedance differences between components is another potential variable, but not usually significant in well designed line level devices. It's easy to conflate and confuse power output capability and loudness based on where the volume control knob is set, but it's not that simple. The best idea is to forget where the level control is set and instead ask yourself "am I hearing clipping compression"? If you are not hearing it the device is very likely still well within it's "clean" power output capability.
