Has anyone compared a Magni 3/ Modi 2 , to a Jot? Which sounds better? Noise Floor? Blackness? So on.
Magni 3 Impressions
- Thread starter CarlosUnchained
clerkpalmer
- Dec 16, 2015
Thanks for the help. Just fired up my magni 3 using my topping nx4 as a dedicated DAC. Headphones are nightowls for the time being. Sound is amazing. Big improvement over the topping alone. So, does anyone thing adding a modi in lieu of the topping will provide any meaningful improvement in sq?If it truly is a line out then it's not double amping. If it's where you plug the headphone in then it's double amping.
Keno18
Member of the Trade: NY Talent Media
Can't speak to that as I use an ifi nano black label. I can say that I've only heard good things about the modi.Thanks for the help. Just fired up my magni 3 using my topping nx4 as a dedicated DAC. Headphones are nightowls for the time being. Sound is amazing. Big improvement over the topping alone. So, does anyone thing adding a modi in lieu of the topping will provide any meaningful improvement in sq?
Robert Padgett
I have not done a comparison, but I have found that Schiit gear mates well with other Schiit gear--which makes perfect sense. The same engineering team are working together. My suggestion would be that a Modi would pair better than another DAC, and I have two Schiit stacks--a Modi MB with Vali 2 and a Modi 2 with Magni 3... and both are very good HP rigs.Thanks for the help. Just fired up my magni 3 using my topping nx4 as a dedicated DAC. Headphones are nightowls for the time being. Sound is amazing. Big improvement over the topping alone. So, does anyone thing adding a modi in lieu of the topping will provide any meaningful improvement in sq?
Logistics
- May 29, 2007
I've been curious about the sound differences between DAC's, but also between DSP's or other sources. For instance: I use a Delta 410 as my PC's DSP, output over digital coax to the Modi. I'm keen on testing a few other sources including, a Sounblaster Extigy and my Harman Kardon DVD-47.
Keep up the good work, fellas! Its nice to see so many success stories with the Schiit stacks.
clerkpalmer
- Dec 16, 2015
Any thoughts on whether a modi 3 is a big upgrade over a modi 2? Looks like I can find a 2 for 60 or less.
Robert Padgett
The biggest advantage the Modi 3 has over the 2 is the ability to use Toslink and SPDIF coaxial interconnects instead of USB, also the power is split off, to a USB-micro port, which you could use an external power supply--either the Wyrd or the iFi iPower 5v. Whether Mike made any changes in the use of AD4490 Delta/sigma DAC chip is not clearly stated, but the other features are certainly valuable.
clerkpalmer
- Dec 16, 2015
Yikes. I don't even understand any of that!The biggest advantage the Modi 3 has over the 2 is the ability to use Toslink and SPDIF coaxial interconnects instead of USB, also the power is split off, to a USB-micro port, which you could use an external power supply--either the Wyrd or the iFi iPower 5v. Whether Mike made any changes in the use of AD4490 Delta/sigma DAC chip is not clearly stated, but the other features are certainly valuable.
SomeTechNoob
- Nov 7, 2016
Basically has inputs other than USB. Can be powered by a seperate USB port.
Robert Padgett
Some folks say it sounds better than a Modi 2, I don't know. I think it is a Modi Uber with a new name, but you cannot go wrong with a Modi 2 for $60, they were closing them out at $59.
SomeTechNoob
- Nov 7, 2016
There have been more than insignificant numbers of failing Modi 2s over the years. They are also known to be extremely susceptible to fluctuations in USB power. The Modi 3 solves a lot of these issues. IMO spend the extra and get the Modi 3 if you're going to go Schiit.
Does the modi 3 match the finish on the magni 3 or do you have to fork out for the modi multibit?
Thanks
Thanks
clerkpalmer
- Dec 16, 2015
Pretty sure it does yes.Does the modi 3 match the finish on the magni 3 or do you have to fork out for the modi multibit?
Thanks
JamminVMI
Mine are the samePretty sure it does yes.
Mine are the same
Thanks.
I didn't want to go to the extra expense or have another power cable with the multibit.
