Here is the full press release.
Bolded words.
I don't think this means "best performing DAC they've ever offered".
It means measures well. Which is cool. Just don't want to suggest that a $100 DAC beats all of their other DACs.
http://www.schiit.com/about/news/99-modi-3-redefines-the-2-figure-dac
$99 MODI 3 REDEFINES THE 2-FIGURE DAC
USB, Optical, and Coax Inputs; USB or External Power
September 21, 2018, Valencia, CA. Today, Schiit Audio announced the introduction the Modi 3, the third generation of its popular, high-value DAC. Modi 3 is a significant enhancement over previous Modi 2, offering 3 digital inputs (rather than just USB), a premium AK4490 D/A converter with active filtering and DC-coupled output, and the capability to be powerd by USB or with an external power supply. A 5V wall power supply and USB Micro cable are provided. Retail price remains at $99.
“This is how you define progress,” said Mike Moffat, Schiit’s Co-Founder, and chief digital designer. “The original Modi in 2012 was a USB-only DAC that worked only up to 24/96, and provided only 1.5V RMS output due to its simple USB power supply. Now, Modi 3 gives you three switchable digital inputs, a better D/A converter, 24/192 capability, a dual rail power supply and full 2.0V RMS output—and we included a wall-wart and a USB cable, for the same price as the original Modi.”
Despite its low cost, Modi 3 is quite a sophisticated design, using custom firmware and a Microchip microprocessor for system control and oversight. In addition, Schiit worked with C-Media to extend its power-sensing-and-reporting code from Fulla 2 to this higher-performance DAC.
“This helps us eliminate ‘draws too much power’ errors,” said Jason Stoddard, Schiit’s Co-Founder. “If you use the included external power supply, Modi 3 reports as a 0mA USB device. This means it works much better with phones and tablets, which usually don’t want a lot of power pulled from their USB ports. Or, you can just plug the single supplied USB Micro cable into virtually any computer, and Modi 3 will get both its power and data from there.”
This versatility allows Modi 3 to be used in the same way as the outgoing Modi 2 and Modi 2 Uber. Connect one USB cable to use it as a single-input, USB-only DAC, or use the included power supply and connect up your optical and coaxial digital sources.
In addition, Modi 3 is the first product developed using new investments in Audio Precision and Avermetrics test equipment, which has
helped it to be the best-performing DAC Schiit has ever offered, when using conventional metrics. A full APx555 report is provided in the product specs.
Modi 3 replaces both Modi 2 and Modi 2 Uber, at $99. It is available for purchase now at schiit.com
About Schiit Audio
Founded in June 2010 by Jason Stoddard and Mike Moffat, Schiit has grown into a leader in affordable high-end audio, with a wide range of products spanning DACs, headphone amplifiers, and preamplifiers, from $49 to $2399.
Press Contact
Denise Martin,
denise@schiit.com
