MAD Ear+ Purist HD thread.
Discussion in 'Headphone Amps (full-size)' started by lmilhan, May 22, 2007.
65 66 67 68 69 70 71 72 73 74
76 77 78 79 80 81 82 83 84 85
  1. joseph69
    Yeah, I was really lost with which headphones Jay still has.
  2. jaywillin
    i had just noticed the other day, you MAD only has one headphone jack, mine has two, i'm guessing there was a change at some point, does your's have the one input, and two outputs on the back??
  3. whirlwind
    Nope....one output only....my Mad is ancient  [​IMG]
  4. jaywillin
    i'm really glad i didn't sell mine !!
  5. whirlwind
     I figured if you would have.....eventually you might get one back.
  6. jaywillin
    yeah, but most of the ones i've seen don't have all of what mine has, i might have had to GASP, order new !!
  7. whirlwind
    Ha....yeah, new is a bad word for me....lol.....there are a few different models.....HD2 ect.....those have 4 tubes....not sure they make it anymore
    As close as I can figure, mine is like maybe 7 years old.
    You use to be able to buy the kits and build them yourself
  8. jaywillin
    the h2 is available, separate power supply, lloyd said it sounds the same, told me i didn't need it
  9. whirlwind
    He is a great guy, every time I have e-mailed him with a question, he has been quick to respond.
    He knows his stuff.......HD800.....no problem.....your amp will be fine.
  10. jaywillin
    i used it to drive the lcd2, fine, no problems at all, didn't get screaming loud, but louder than i would ever listen to
  11. parbaked
    Super 2 has more power and even lower output impedance.
    It also uses EL84 output tubes so lots more options for tubes.
    Sound is similar but it does have more power/gain if you need that...
  12. jaywillin
    seeing your super 2 at some point after i had gotten me HD, prompted my query to the good doctor
  13. Fireboy
    That's a beauty too whirlwind. I'm liking the LCD2 with mine now.
  14. whirlwind
    Thanks.
    Very nice there yourself  [​IMG]
  15. kramer5150
    Awesome... Something I've always wondered... is the Super 2, basically a low power EL84-Hammond 119DA coupled speaker amp (with common grounded outputs)?
