"Mad Dog" by MrSpeakers, modified Fostex T50RP review
- Thread starter dorino
jerg
- Aug 11, 2010
So that's where all the gold used in the tracings symbolize.
A Gold Digger
I win, where do I claim my prize?
- Oct 22, 2011
I think this might be the HD800. The HE-6 isn't picky as long as the amp is loaded. Gold Digger in IMO.
This is fun.
A fu*king BIT**
This is fun.
paradoxper
HE-6 is way more fussy. But I think Gold Digger is apt as well.
This is fun.
- Oct 22, 2011
Well I guess a Bitch can also be a Gold Digger. Win win I guess?
It's hard to top the LCD-2 = Amp person
Impulse
So that makes the HD 650 a cougar?
paradoxper
Damn you, prep, do ya see what you've started.
jazzerdave
- Aug 25, 2012
Not to pile on with Hutnicks, but if you choose the aha-120, you're definitely choosing solid state. I'm curious though, do you actually have both the aha-120 and the Mad Dogs? If so, it's nice to add another capable amp to the list.
Discrete is actually solid state. Now that I am through being a pain What do you like about the 120? How Portable is it? How long do you really get on a battery etc?
I am in the market for a Portable discrete amp and this is on the short list.
Wow lot of debate here on md's and lcd-2's and whether or not they require a fancy amp. Personally I think that they both def. change sound with different amps. However I would say that v-shaped cans as a whole, in my experience, are harder to match up and that their sound change between amps usually (but not always) is more dramatic. As far as tubes or ss I choose neither aha-120 all the way.
C.C.S.
- Jan 20, 2010
I don't know if people have thought about doing this, but everybody who owns Mad Dogs with Alpha pads should try it out. Rotate the pads a little bit so that the back of the pad follows the slant of the back of your ear, similar to how Sennheiser headphones fit. Comfort on my pair improved significantly and I'm getting an even better seal now. Also, isolation improved by a few dB and perceived bass presence rose just a little bit (probably a result of the better seal and isolation).
Hey, nice suggestion. I'd been tipping the phones back a bit to rest more on my crown, your fix does the same thing more intelligently!
If anyone else tries this I'd love to hear the result...
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
mechgamer123
I can verify that this. Just tried rotating the pads on mine a bit and the slight pressure against the tip of my ear has been alleviated. No commend on how it changes the sound or seal though until I evaluate them a bit more.
Quote:I don't know if people have thought about doing this, but everybody who owns Mad Dogs with Alpha pads should try it out. Rotate the pads a little bit so that the back of the pad follows the slant of the back of your ear, similar to how Sennheiser headphones fit. Comfort on my pair improved significantly and I'm getting an even better seal now. Also, isolation improved by a few dB and perceived bass presence rose just a little bit (probably a result of the better seal and isolation).
Actually no change for me, but I got a pretty big head so the seal is already superb and I find the bass to be rich. But the comfort did get even abit better, as they are more angled to my ear now. My wife complained that they did not have enough bass for her, was sorted with the turning of the pad. Yeh she is a basshead
jibzilla
- Mar 27, 2013
yep they sound really nice together.
jazzerdave
- Aug 25, 2012
Impulse
New and improved Alpha pads, rotated for your pleasu... Err, comfort.
