simonpking
- Nov 12, 2012
[size=10pt]Good Solution. I had thought to myself that using the v-moda cable might cause issues with the TRS jack. Given it doesn’t lock in place like the stock cable it seems like ongoing use could cause a weakness in the receptacle. Has anyone had any actual problems with this? Happy to be paranoid.[/size]
Yes, I believe you are quite correct on your response. However, the female TRS receptacle that is built into the cup on the Fostex headphones, can be a bit weak. It is not fully molded to the cup itself, but is just molded on two small area. The rest is "open" and was designed to use the stock twist-in cable from Fostex, which would seal those gaps. When using another cable and switching from the stock twist / locking cable, I have taken some small pieces of plastic and epoxy by which I adhered them to the inside plastic components to further secure the plastic mounting area for the jack. Once that was done, the strength of the plug / receptacle in the cup itself was much, much more secure for the long haul with the Fostex headphones.
