Anda
- Feb 2, 2010
How do you use the Hiface 2 as sound output in OS X? When I choose it in the sound preferences there's no sound. I'm trying to help a guy who wants to use iTunes, Spotify and VLC.
I'm thinking about trying the Sabre D18 dac from grant fidelity. I already have a Teralink x2, my question is: would a Hiface 2 be a great improvement over my Teralink when testing the D18?
BTW, M2Tech has released an update of Hiface2 ' firmware early this week![]()
Thanks for the tip but it is a driver update not firmware. They told me it was to improve compatibility with Windows. Any other changes so far they are not talking. When I installed it today I noticed a slightly smoother/sweeter high frequency response with no lose in detail. The effect is a bit more overall transparency. The change is slight but noticeable on my setup. I really think this device is a remarkable value.
Chodi,
To compare notes, what Buffer settings are you using ? USB Steaming Mode and Asio Buffer Size? on the Hiface 2 control panel....
Many thanks
I have it set on "Standard" streaming mode and 2048 samples (default). I am using Windows 7x64 with an i7 3770 and 8gig of memory so those setting are not going to cause any issue for me. I use Foobar and have it set to load each selection I play into memory automatically so it reduces latency to an insignificant issue (only takes a second). Honestly I think the Hiface Two with this latest software does as much as anyone could ask of a usb converter. What I think they accomplished with this update was to remove some very slight edge in the upper frequency (we are talking very small edge that was barely noticeable on some recordings). After all, the whole point of the transport is to not color the sound and I think they have accomplished that in spades.
Your pops and clicks only between tracks or also while music is playing?
While music is playing. It is only on 'Safe' streaming that the pops and clicks are eliminated! Hence, my choice of using Safe streaming. I am using a powered usb hub exclusively for the HiFace, which brought on a nice sonic improvement, making images more palpable.........
Yes I also have mine on a powered hub and it does help. I would not be concerned that you have to choose Safe streaming. That is simply a function of your hardware. I have a pretty high end desktop so my computer is not working at all to run these programs.
