Originally Posted by morsel
VC: AMB and I talked a bit about using a shaft extension, but we were a bit unsure how others would feel about this. How much of a pain is it to install a shaft extension and panel bearing?
I know about the need to order the case anodized, not painted, but what's this about countersinking the screws, can you give us more detail? I assumed no one keeps the stock screws.
Are you OK with the 12×8×3" case size?
The extension is a fairly simple to use, requires only a *little* more insight than a panel-mounted pot. Mainly calculating the height for the hole from the panel base, typically lower than the chassis base due to overhang. A table could be made giving the offset based on 1/8" standoffs under the PCB, 1/4", 3/8", etc. To this you would add the overhang dimension of the panel.
As for the countersinking, you have to ask Jeannette or John at Par very specifically. They will furnish screws then. And instead of painted zinc screws, they then furnish proper black screws, and stainless for the faceplate. You may opt to not have the faceplate countersunk if you wish to use Allen-style machine heads, or button head screws. Having the entire chassis anodized in black, and the faceplate in silver, with countersunk holes throughout runs about $55 shipped for a 12"x8"x1.75"/2" (1.75 box/2"faceplate). That is also including the fist thickness upgrade on the faceplate, which is well worth it, I think. I believe it is 1/8" thick.
As for the case size, that's tough. The case I describe above is perfect for a PPA, is almost exclusively what I have used. But it is tight vertically. The next (stock) height is the 3" case you describe. This seems tall to me, at least in the 12"x8" size. I think I would do one of the following:
Either keep the 3" height, and get the 16"x8" or 16"x12" case to keep proportions nice, or...
stay with 12"x8", and ask for a custom 2.5 or 2.625" height as a custom job.
I don't believe they gouge you on price, but you will wait for it. As it is they take about 10 days to 2 weeks for a chassis or two in stock sizes, since they do make them to order, even when 'stock' sizes. I think by stock it just means that they have jigged settings or routing packages saved for these sizes. They don;t actually have them truly 'in stock'.
They (Par) are very nice people, and the work is pretty good, but it is imperative that you are very explicit with your preferences.
