DCameronMauch
- Dec 17, 2002
Morsel: Yes, there is a DC offset at the opamp output, thus limiting your voltage swing. But the schematic you showed has the same problem. The opamp is connected to the top of the biasing circuitry. Which has to be a few volts above ground to start conduction. To avoid the problem, it would have to be connected to the middle. Of course the bias circuitry would have to be different, since this one doesn't really have a middle. I believe the original Sheldon Stokes article mention this. In a design I am playing with, I use balanced outputs, so even with the higher voltage requirements of Senn's, +-12Vdc rails is more than enough.
AMB: Yeah, single ended is definitely not very efficient. But I thought the project statement indicated that there was no concern for power supply requirements. Also the target enclosure should have more than enough room. PCB area could be reduced by mounting the power mosfets horizontally off the end of the board. I am not sure if project cost would really be impacted that much. Another way to decrease heat dissipation is to change the bias current AND the voltage rails to match the intended load. For example, Grado's need more current and less voltage versus Senn's. But the overall power requirements of both headphones are roughly the same. Just some food for thought...
