amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
I think peranders is proposing to use a MOSFET for the Vbe multiplier and put that on the heat sink with the output MOSFETs. This provides a thermal feedback loop.
This sort of technique is common practice with class-AB power amplifiers to prevent thermal runaway, due to the positive thermal coefficient of BJT devices (quiescent current creeps up with increasing temperature).
Doing thermal sensing limits heat sink choices, because all three devices (both output transistors and the Vbe multiplier) must be mounted to a common heat sink to be meaningful. It also complicates PCB layout for the same reason, and we want to avoid the need to run wires from the board to the sink-mounted Vbe multiplier transistor.
In practice this is not necessary because bias drift is not an issue with this amp at all. The negative thermal coefficient of the MOSFETs will self-regulate the bias very nicely. This is one of the major advantages of MOSFETs. There is a period of time after cold turn-on where the quiescent current goes higher than the desired target idle value, but that actually makes for quicker warm-up times. Once warmed up, the quiescent current is rock steady. This, and the fact that MOSFETs have no secondary breakdown and SOA (safe operating area) concerns is why pro-audio amps nowadays are almost exclusively MOSFET designs.
-Ti
-Ti
