The Lyr amps become 100% SS when the LISST tubes are used.Ok! But using LISST tubes: is it like having a true ss-amp? Or are there some differences?
Lyr 3 - The new Coherence™ and Continuity™ hybrid amplifier from Schiit - Impression & discussion thread
- Thread starter ProfFalkin
antoramp
Ok perfect... So I'll add a LISST tube in the shopping chartThe Lyr amps become 100% SS when the LISST tubes are used.
Just FYI,Ok perfect... So I'll add a LISST tube in the shopping chart
While I'm not totally sure about this (you should double-check with your dealer), by selecting the LISST tube when purchasing the Lyr 3, you are substituting the stock tube for the LISST, so it won't ship with both, just one or the other.
If you want both, you need to also add the one you didn't select to the order, and the cost works out to be nearly the same ether way you do it.
antoramp
Ok I'll take care of this when I buy the AmpJust FYI,
ProfFalkin
- Aug 29, 2016
It is true SS, but I think a more important question is: Does it sound good?Ok! But using LISST tubes: is it like having a true ss-amp? Or are there some differences?
A: It's not Terrible. Any of the stock tubes sound noticeably better. If you want SS, get the Jotunheim. It has better sound stage than the Lyr3 + LISST, better clarity, etc.
antoramp
Ah! But I’ve heard that The Jotunheim was quite bright, isn’t it?It is true SS, but I think a more important question is: Does it sound good?
lentoviolento
- Feb 17, 2017
dove l'hai visto a 580 in italia? proaudio non lo ha ancora a listino e a maggio quando sarà disponibile in italia si suppone costerà quanto costa adesso il lyr2 ossia 490....
comunque il jot io lo eviterei perchè devi usarlo in bilanciato e per ogni cuffia devi poi avere il cavo terminato in bilanciato.. altri soldi
ProfFalkin
- Aug 29, 2016
Mine isn't.Ah! But I’ve heard that The Jotunheim was quite bright, isn’t it?
Out of the 4 Jots I've heard, only one was a bit tizzy up top, and that was a release-day ordered Jot.
ProfFalkin
- Aug 29, 2016
I disagree. I used single ended connections on my Jotunheim as well as the balanced, and they both sound fine.dove l'hai visto a 580 in italia? proaudio non lo ha ancora a listino e a maggio quando sarà disponibile in italia si suppone costerà quanto costa adesso il lyr2 ossia 490....
antoramp
https://www.schiit-europe.com/dove l'hai visto a 580 in italia? proaudio non lo ha ancora a listino e a maggio quando sarà disponibile in italia si suppone costerà quanto costa adesso il lyr2 ossia 490....
Il loro sito ufficiale
Per i cavi per me non ci sarebbero tanti problemi perché li ho già in realtà... xD
antoramp
ok that could be a game changer for me... The possibility to have The balanced connection...Mine isn't.
antoramp
How can you compare The Jotunheim Single Ended vs Balanced Vs Lyr 3 with true tubes ( like the Russian or the one you prefer ) in background noise, clarity, imaging and bass response? Thank youI disagree. I used single ended connections on my Jotunheim as well as the balanced, and they both sound fine.
ProfFalkin
- Aug 29, 2016
With headphones.How can you compare The Jotunheim Single Ended vs Balanced Vs Lyr 3 with true tubes ( like the Russian or the one you prefer ) in background noise, clarity, imaging and bass response? Thank you
bcowen
With headphones.
LOL! I can't even believe you'd mention headphones in a forum like this. Bad, bad.
terminatetrails
I can only speak to experience comparing Jot to MJ2. There is no comparison IMHO. MJ2 has that smooth tubey goodness that makes Jot feel a bit sterile to me (not bad, just cleaned up). If Lyr 3 is approaching MJ2 territory (or surpassing it!! as some on here seem to indicate), I would not worry about going balanced. You will get full power from Lyr 3. If I were starting from scratch and wasn't already so far down this balanced rabbit hole, I might change course myself. But hey, with MJ2/Gumby I have a premium stack for one place, and with Jumby I have a portable mb amp that is transportable and I don't have to worry about breaking tubes. It literally travels in my gym bag.How can you compare The Jotunheim Single Ended vs Balanced Vs Lyr 3 with true tubes ( like the Russian or the one you prefer ) in background noise, clarity, imaging and bass response? Thank you
Bourbon of the moment: Blade and Bow, Louisville, KY
