I have that psvane tube as well for my Lyr3. Really enjoy it, but it's a tight fit and not simple to remove since it's deep in there. I'm curious, where'd you find the socket saver? I've looked around, but not confident in the quality of some I've seen... I think it'd be worth it to have one if there's a good version out there? Recommendation by chance?Thanks!
These socket savers are not the cheapest, but are very high quality and highly regarded by many here (myself included). Pulse Tube store is Tubemonger, BTW.
You're correct in saying it's quite the cost increase for the general market, but went in for one regardless...thanks for recommendation. Hoping the quality and high-regard keeps me satiated with the purchase. At least I'm going with that... looking forward to giving it a try.
Just got my Lyr 3 today. I let it warm up for an hour before I tried it but sounds a little stiff (swapped out the stock tube with the Tung- Sol 6SNTGTB)
How long would you all say it needs in hours to warm up?
I thought about getting a tube saver for my Shuguang Treasure CV181-Z but decided to get creative with a dremel bit in my drill press. The mod is not for the faint hearted… it took some time to widen the opening. Glad that I tackled it. I’m really enjoying my Lyr 3 and I think it’s a keeper.
No, the ceramic base has a taper that is too big for the opening. There may be inconsistancies and yours may fit? Otherwise you will either need a tube saver or take off the cover and file back the opening.
