LP6 Ti 199 -- The Most Expensive and Technical Advanced Portable Player on The Planet?
Mar 24, 2022 at 12:03 PM Post #332 of 583
For lots of folks it is. But for lots of other folks, no it isn't. And...the issue has been debated ad infinitum.
Yep everyone have different needs. My library is only 3,000 songs. If anyone have 20,000 or more songs they definitely need more.👍
Mar 29, 2022 at 7:36 PM Post #334 of 583
Sorry but the latest updated firmware of LP6 Ti is 1.0.0.2?
Because from here it is not clear:
https://www.musicteck.com/lp-download
If you follow the link (3rd from the bottom) for LP6 Ti, you will find below. So it appears the latest is 1.0.1.4.
Mar 30, 2022 at 8:12 AM Post #336 of 583
Thank you. Do I have to put both downloads (DSP Config and LPFWPGK ....) inside the dap?
Put the DSPConfig if you want to try the sound styles for Traillii, etc (I forgot which ones are included in this one, lol, only two or three, I think)
Apr 5, 2022 at 12:37 AM Post #337 of 583
How do you all compare LP6 TI AE with other players? As for me with the right IEM, LP6 TI makes others sound like a child play. Might be slightly exaggerated but feel like others sound like a good transistor radio comparing to Ti playing at studio quality reproduction when it comes to realism. :)
Before I would be skeptical but after hearing the LP6 TI or the Ti7, I have to agree. One needs to remember these are very limited editions so not a lot of people got a chance to hear them. I have let my friends hear them and it blew them away. I think the R2R technology with the sheer power of the Amp on these can bring any IEM alive on these DAPs. BTW I have tested a large number of players and IEMS; I thought the O'bravo CU were mediocre but I went back again to the shop and testing them on the TI7 and it just brought these IEMs alive. Ok, it could drive about 80% of the OBravo CU but that difference is all that it takes to get most of the potential out of these IEMs. It is rumoured the LP7 is coming out at the end of 2022. I don't know how they can make the sound any better but they can improve the follow:
1. Battery life
2. GUI and user interface
3. Gorilla glass with a Hires screen
4. Gap-less play
5. 20% more power and more intermediate settings in the Gain
6. Try to keep the size portable
7. % for battery life (seems TI7 was taken away)
8. Have a toggle setting to see volume level on screen and to not have it
9. Larger on board disks storage
10. The quality is already very good on the materials used but take it to the next level with materials at least keep to Titanium
Apr 5, 2022 at 12:55 AM Post #338 of 583
Apr 5, 2022 at 1:42 AM Post #340 of 583
There is no such thing as LP6TI 199. It is only LP6TI. 199 is refers to 199 units made worldwide. LP6TI and LP6TI 199 is the same thing. . There is also LP6TI AE and LP6TI AE 99! 99 units made worldwide. Lol.
From my understanding there was only one anniversary edition which was the 7th anniversary one which was limited to 99.
Was there another anniversary one?
Apr 5, 2022 at 1:44 AM Post #341 of 583
Apr 5, 2022 at 2:47 AM Post #342 of 583
Thanks for the clarification ...... but if you look at the two links (one from musicteck and one from google drive) there are different firmware regarding LP6 Ti. On musicteck it reaches 1.0.1.4. On google drive (LP6 T199) it arrives to 1.0.0.7 Which one do you recommend to put ???
Apr 5, 2022 at 2:56 AM Post #343 of 583
yep
Apr 5, 2022 at 3:41 AM Post #345 of 583
:thumbsup:
