Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Apr 27, 2023 at 3:11 PM Post #8,401 of 9,552
Weight, handling and comfort also factor in. It doesn't matter how good any piece of audio gear is, if it's uncomfortable or inconvenient to use. People are fickle that way! :rolling_eyes:
Overall I agree, but I can like ugly and not usable cable for its sound.
May 7, 2023 at 5:26 PM Post #8,405 of 9,552
Just opened my Tripowin Altea cable. It's beautiful ❤️
May 8, 2023 at 10:55 AM Post #8,406 of 9,552
How do we calculate the resistance of the cable ? .. i mean .. if a cable ground measure : 1.2 ohm L: 1.2 ohm and R :1.3 ohm ... And the contact resistance of the multimeter is : 0.6 ohm ...
Is the sum of all contacts minus the resistance of the multi. Considered the total resistance?
OR ..the resistance of one contact minus the multi resistance is the cable resistance ?
May 9, 2023 at 1:02 AM Post #8,407 of 9,552
XINHS 16core copper & adapter
Not sure if he have more of this one, maybe if one ask. It's good in the hand, will test it later today compared both to ISN C16 and XINHS copper 4core( i guess his best copper)
May 9, 2023 at 3:38 AM Post #8,409 of 9,552
It's pretty for sure.
Why do so many manufacturers use a straight plug not right angle though?
I want angled for when I use my DAP and straight for my dongles or desktop 😅
I believe most want it straight and that's why it's the standard. Probably a cost thing also.
May 9, 2023 at 10:09 AM Post #8,410 of 9,552
May 9, 2023 at 11:35 AM Post #8,411 of 9,552
Makes sense I suppose.
I'm either mobile use or static but either way my phone is my source so I prefer the less obtrusive form of the angled jack.
I can't see the production cost being an issue though. Straight or angled, once the tooling is sorted the cost should be the same.
May 9, 2023 at 11:35 AM Post #8,412 of 9,552
I have the Graphene varient of that adapter. The Cable itself is like any other Cable from XINHS which is to say that it's good. The connectors however could use some improvement. As you can see in the attached Image, the outer metal cover (which is a finger print magnet) keeps sliding off when I try to detach the adapter. Also the strain relief bit keeps detaching too.
No other issues with sound, just the cosmetics need some work.
May 9, 2023 at 3:57 PM Post #8,413 of 9,552
Angled connector wins for strain relief for mobile use! Straight jack out of phone or DAP is way more prone to be subjected to strain at 90 degrees. Pivot of angled plug in socket reduces that. Ditto with side mounted socket in laptop. For inline use like plugging into desktop or dongle DAC, then straight plug is easier to use. Only my opinion (even if anyone who disagrees is categorically wrong).:ksc75smile:
May 9, 2023 at 4:01 PM Post #8,414 of 9,552
After having tested for a few hours, I can say that I like it. At first listen going from a good 4 core copper from XINHS, I could hear better note definition in the bass and harder bass impact. Mids and treble seemed the same. But going back after an hour its so close, as the perceived change might be due to less resistance in 16core so the sound is slightly louder.
Maybe I also get my NiceHCK RubyCat before the weekend.
