Thanks again. That rounded treble with better resolution (and more weight, hopefully) sounds good. Will try it.All my IEMs are under $300 due to I cannot cross the psychological barrier when I believe that price difference does not give the same increase in sound quality. So my most expensive cable costs $180. Sorry.
That CEMA cable gives quite smooth sound, with tighter and deeper bass, the mids are very good for female vocals, the treble becomes like as rounded, without sharpness, but with better resolution and details.
Low end. Cheap. Generic. Otherwise bang for buck cable thread!
- Thread starter Dsnuts
- Tags
- aliexpress cable
I'm not sure about the term "more weight treble", but warmer and softer treble - that's about the cable.Thanks again. That rounded treble with better resolution (and more weight, hopefully) sounds good. Will try it.
HiFiRobot
- Apr 1, 2013
Another one, this is the current top selling cable from the second XINHS store,
XINHS Headphone Cable HIFI Store
https://www.aliexpress.com/store/1102081218?
XINHS 8 strands of silver-purple single crystal copper plated with silver
Conductor: 5N single crystal copper plated with silver
Core: single strand 14*0.05mm*8 strands = 112
Wire diameter: single strand 1.0mm
https://www.aliexpress.com/item/1005004394239656.html?
Ali part no 1005004394239656
Measured resistance using Uni-T UT161D
Right channel: 0,4Ω Left channel: 0,4Ω Ground right: 0,1Ω Ground left: 0,1Ω
8 core, pretty soft and handles well, not much microphonics, connectors and splitter feels like alu or some other metal and seem ok to me qualitywise, earhooks not as stiff, the material has a hint of being sticky but it is very slight, would have looked better with silver hardware on the EA500. A solid budget cable. Perhaps the Xinhs/ivipQ stores has the same cable in other colors if you are not feeling purple.
Top to botton
Top to botton
- XINHS 8 strands of silver-purple single crystal copper plated with silver
- ivipQ 8 Cores OCC Silver Plated and OCC Mixed Braid "ivipQ-65" https://www.aliexpress.com/item/1005003688146295.html Ali part no 1005003688146295
- XINHS 8 cores pure silver and single crystal copper mixed braid https://www.aliexpress.com/item/1005002350509830.html Ali part no 1005002350509830
- NiceHCK GCT5 https://www.aliexpress.com/w/wholesale-nicehck-GCT5.html?
Carpet
XINHs often have a silver/black 5N 8 core silver plated cable with the same spec as the purple/silver one as their cheapest discounted option. Another thing to bear in mind is that XINHS haven't been supplying the smaller cases for a while, but ivipQ still does.Another one, this is the current top selling cable from the second XINHS store,
8 core, pretty soft and handles well, not much microphonics, connectors and splitter feels like alu or some other metal and seem ok to me qualitywise, earhooks not as stiff, would have looked better with silver hardware on the EA500. A solid budget cable. Perhaps the Xinhs/ivipQ stores has the same cable in other colors if you are not feeling purple.
Top to botton
bamboostreet
Tripowin has made very good cables (flexibility, color, quality control) like tripowin jelly or zoe. A little overpriced, but i had a few bad quality cable from kbear and nicehck, so tripowin never disappoints...Hi All,
I did a quick browse through the 500 odd pages and need advice.
I'm using a 64 audio Fourte and I've tried these cables so far:
Of all these, I've found the Tripowin C8 to be the best sounding thanks to the way it tames the highs. But I feel like there's more to be explored. I've been recommended the Kinera Leyding but I'm yet to try them.
- The old stock cable
- Tripowin C8
- Penon Pac480
- Impi by Doctor Juggles
- EA Eros S
I don't want to go to the pricey 1950s territory. Can you guys recommend something that lives upto the title of this thread?
True. For the price, the C8 really does great. Haven't tried Kbear or NiceHCK yet and don't think I will anytime soonTripowin has made very good cables (flexibility, color, quality control) like tripowin jelly or zoe. A little overpriced, but i had a few bad quality cable from kbear and nicehck, so tripowin never disappoints...
KarmaPhala
Thank you. I don't mind spending on cables but so far, I've liked the C8 more than the pricier ones. I'll check the CEMA cable. If I were to stretch the budget to $300, what would you recommend?
https://www.head-fi.org/threads/mid-priced-iem-cables-thread.927268/
you can join this thread for $100 and up price range
Think I might have a bit of a BlackCat addiction!
Thank you, will check!https://www.head-fi.org/threads/mid-priced-iem-cables-thread.927268/
Carpet
Five? I was feeling guilty at having bought four! NiceHCK is responsible for a good chunk of my cable collection. PurpleSE and C16-3 are another couple of favorites. I only buy during sales and never had a faulty cable from them. XINHS, ivipQ and Tripowin have been good too. Only had a couple of KBEAR cables so really can't comment, but all included cables with TRI IEM sets have been fine.
Neithan
My cables have arrived!
From top to bottom:
NiceHCK BlackCat
NiceHCK BlackSoul
NiceHCK PurpleSE
Some considerations...
The BlackSoul doesn't look as dramatic as I thought.
The BlackCat looks amazing.
The PurpleSE looks better in real life.
Now, let's start with the IEM rolling
Been a fan of the XINHS silver plated copper for along while, decided to also get the pure copper version. Its a little thinner, softer and flexible.
As for sound its an very good copper cable for its price, not a cable that is going to hold back your IEM.
https://www.aliexpress.com/item/100....order_list.order_list_main.59.5c221802jgi6nd
https://www.aliexpress.com/item/100....order_list.order_list_main.94.5c221802jgi6nd
gaspir324
- Aug 2, 2011
Could someone suggest a replacement cable for my IE80? The thing is I'd prefer if it had a microphone and possibly controls (volume+pause/double press for next)?
Carpet
Not sure if IE80 takes standard MMCX. Try Faael or Openheart?Could someone suggest a replacement cable for my IE80? The thing is I'd prefer if it had a microphone and possibly controls (volume+pause/double press for next)?
Top to botton
Could you please make a quick sound comparison between those two ? looks interesting
