WilliamBlake
you could try this one https://it.aliexpress.com/item/1005...db16559906523633693e2bb8!12000028971974359!shAndromeda
thought the sameIt looks gorgeous.
any of these suitable for a shure headphones that uses mmcx (but according to reviews the shure headphones mmcx connectors are longer). ThanksWell, getting ready for the summer sale on AliExpress, I would like to pick some custom cables for XINHS, but I need some advice here, Because I'm a little bit lost about materials, thickness and quality of materials.
This one is my prefered setup, twisted, a good looking cooper, perfect for a yuan li or moondrop kato.
€ 41,54 35%OFF | XINSH 4 Core 5N UPOCC Single Crystal Copper Upgraded Cable with MMCX/2PIN/QDC/TFZ 2.5/3.5/4.4mm for KZ TINHIFI T2 BLON BL01
https://a.aliexpress.com/_v1qMK6
But, after some chat with XINHS I see these cables
€ 25,19 25%OFF | Factory direct sales 4 strand single crystal copper LITZ struct Headphone Cable HIFI Balance Audio Cable Conversion Cable Line
https://a.aliexpress.com/_uQhwDC
€ 29,34 35%OFF | Factory direct sales 4 Core Copper Plated Gold Mixed Upgrade Line HiFi Headphone Wire MMCX/0.78mm 2Pin/QDC/TFZ For SE535 UE900S
https://a.aliexpress.com/_u8uUm2
Both of them could be twisted, so no problema about the looking.
Anyone could tell me about thickness quality, and wich is the most similar to the first one?
Xinhs could make u one for sureLooking for a 4.4mm to 4.4mm braided cable. Suggestions? Thanks
Your links don't work. At least for me.Hello,
Mainly looking to buy some cables with no integrated ear hooks in the upcoming sale but I'm curious if there's any real difference in quality/characteristics between these pure copper and copper silver mix cables.
Could anyone tell me if one of these cables would be noticeably better than the others please?
https://www.aliexpress.com/item/32954926911.html
https://www.aliexpress.com/item/32973114057.html
https://www.aliexpress.com/item/1005001483466249.html
Thanks.
Hmm, that is odd.Your links don't work. At least for me.
With what are you going to pair it?Looking for a 4.4mm to 4.4mm braided cable. Suggestions? Thanks
Just go with the one looks nicer to you. They don't have much difference and any rating that I could see.Hello,
Thanks.
T60rpWith what are you going to pair it?
They are high purity copper (purity isn't specified and they aren't OCC) so the difference between the first and third is purely cosmetic. I have the last two and they are both very comfortable. The second one is SPC/Copper mixed so may sound slightly brighter. The first two are on sale tomorrow, I'd buy whichever one you like the look of.Hello,
Thanks.
Looking for an upgrade cable for my Olinas, predominantly for comfort but also build quality. No issue with stock but whilst they’re on offer what would the pros and cons of each of these be?
For reference I’ve used the C16-1 happily for quite some time and find it good quality.
£33.66 57% Off | NiceHCK C24-2 24 Core Silver Plated Copper Alloy Copper Headset Cable 3.5mm/2.5mm/4.4mm MMCX/NX7/QDC/0.78 2Pin for MK3 LZ A6 A7
https://a.aliexpress.com/_mPwragS
£30.32 51% Off | NiceHCK LitzPS-Pro 8 Core 4N Litz Pure Silver Earphone Cable 3.5mm/2.5mm/4.4mm MMCX/NX7/QDC/0.78 2Pin for CIEM MK3 ST-10s LZ A7
https://a.aliexpress.com/_m0ue2fC
Is the LitzPS worth the premium over the C24?
I have c16-3 cable. Very soft but easily tangling. Keep that in mind.
Thanks very much for the guidance guys, I've gone ahead and ordered a couple of cables.They are high purity copper (purity isn't specified and they aren't OCC) so the difference between the first and third is purely cosmetic. I have the last two and they are both very comfortable. The second one is SPC/Copper mixed so may sound slightly brighter. The first two are on sale tomorrow, I'd buy whichever one you like the look of.
