my iem is moondrop aria 2021. i have a cable xinhs SPC 2 core,
https://a.aliexpress.com/_mMgQR1l
I paired this cable with moondrop aria, it turned out to be very good and synergistic, Sound Qualiity.
This cable is also a stock cable from the Blon A8 Priometheus.
But, unfortunately the connector pin from the xinhs cable can't fully fit into moondrop aria 2021. only 3/4 can into my aria, so it can be dangerous if not careful.
And I decided not used it again, and look for a replacement for the SPC cable.
I'm looking for best budget SPC cable under 22 usd.
I just found 3 budget SPC cables :
1. trn t6 cable,
https://a.aliexpress.com/_mMHHHyj
2. Cable tri through,
https://a.aliexpress.com/_m0Sdpnt
3. Cable KZ 8 core 784 silver blue,
(whose connector I will replace the re-connector with a 2pin 0.78mm rockstone connector.)
https://a.aliexpress.com/_mN9NLrp
4. Cable Tripowin Zonie 16 Core,
https://a.aliexpress.com/_mOhMHKX
5. **** 16 core
https://a.aliexpress.com/_mNdxa2L
Kbear, nicehck, etc
which is the best SQ (Sound Quality) of those budget SPC cables from your experience? If there are other SPC cable recommendations, which are better than this, please let me know. thank you very much.
If can give me the link or pic.
1. trn t6 cable,
5. **** 16 core
Kbear, nicehck, etc
