One day I'm gonna fall off my chair, and get strangled by my cables on the way down final destination style
With this song playing in the background.
The NiceHCK LitzOCC in the middle. Just a bit thinner than FAAEAL but as I said, generally a nice affordable choice for a dark copper look. My 4 core XINHS on the left as someone asked about it. Again, on the thinner side as it is 10 or so strands of silver per core.What if instead of the **** cable it was this NiceHCK vs the Faaeal copper cable?
https://www.aliexpress.com/item/100....store_pc_groupList.8148356.51.7e157b5fJb8GQj
Thanks Paul. I ordered 1 of the copper and 2 of the SPC cables with mics below. Finally decided to place a Xinhs order lol. Excited and interested to try a twisted design instead of braided.I am almost positive I added that one to the dBase but as the Unspoken brand. It is quite soft, a bit lighter than A1, only 4 cores. I am a big fan of it. On the right side of the pice below.
Not sure I have measured my 4 core pure silver, either it is in the list already or I forgot. It is definitely on the thin and fragile side but I like it as it is near weightless. On these budget lightweight sets like the MT1, it works great, iem weighs nothing and works with a cable that weighs nothing.
Faaeal is the usual choice and I would take it over the other
For the extremely high impedance cables the difference clearly lies in the presence of a microphoneDug out more skeletons from my closet XD
Default unbalanced cable from QDC, comes with most their iems - 0.32ohm. Very thin, rubbery cable. Not too bad for a stock cable. Not sure where to buy it, but it looks like this balanced version.
Default cable from 64Audio. 0.19ohm. Thin, ugly cable that tangles easily and many people hate. Hmm pretty good impedance for stock cable.
TRN 8 core silver plated cable $9 - 0.31ohm. I guess the wire quality itself is good but the connectors and splitters are very plasticky. Can't recommend
https://www.aliexpress.com/item/4001230563513.html
KZ 784 strand cable $12 - 0.12ohm. Good impedance, Best impedance to price ratio so far. Cable is chonky and feels durable and sinks in like play dough to the touch. Super good value if your iem uses a qdc connector.
https://www.aliexpress.com/item/1005002403946248.html
The cheapest cable in penon $19.90, or 9.90 if you purchase with something else. 6 core cable - 0.17ohm. I just love its simplicity and feel of the cable and hardware. Cheap enough to abuse at less than $10.
https://penonaudio.com/accessories/earphone-cable/6-strands-19-cores-silver-plated-iem-cable.html
XinHS 2-strand twisted $25 - 0.20ohm. Very pretty blue colour. 2 cores for simplicity, light, soft and silky? Go for this if the cheaper white one is too bland for you XD.
https://www.aliexpress.com/item/1005001843312645.html
NiceHck 4N copper $40 - 0.17ohm. Nothing really special about the copper wire, slightly washed out and tangly. But at least some effort was put into the other hardware for a glittery effect.
https://www.aliexpress.com/item/4000097502378.html
Lunashops 0.30ohm $25. Very soft flexible cable, impressive build, though a bit plain looking.
https://www.aliexpress.com/item/4000703753869.html
KZ stock brown cable $3 - 0.88ohm. We got a new winner XD RIP
https://www.aliexpress.com/item/4000415495758.html
Penon Audio ISN AUDIO S8 $32.50 - 0.14ohm - On closer look, it is silver with some copper streaks. Good build, nothing to complain about.
https://penonaudio.com/isn-audio-s8.html
Haldane 7N silver plated $48 - 0.20ohm. Terrible cable that is stiff as heck and microphonics are able to overwhelm the music. Avoid!
https://www.aliexpress.com/item/33001487523.html
JCALLY 0.15ohm $13 on Ali, though I can get it less than $10 on shopee. Good looking cable for less than $10. Ive heard bad things about this brand, like unsoldered wires and such. But this looks impressive, at least externally and in measurement. Best impedance to price ratio so far for 2pin cable. We are getting to ASR meme levels.
https://www.aliexpress.com/item/4000383436202.html
KBEAR's cheapest offering $4 - 0.51ohm. Can't say it looks bad. Very simple looking cable with the microphone option, but maybe bump your budget up for a penon or jcally cable in the sub $10 range XD.
https://www.aliexpress.com/item/4000272626428.html
Dunu Duw02 $79 - 0.65ohm, about 0.5ohm on other channels. A popular cable, but at this price, I can't recommend it. Maybe it is due to the swappable plugs, idk. Externally though, its a very flexible, light and attractive cable
https://www.aliexpress.com/item/4000898512134.html
My 2nd Cema copper-silver plated copper mix, $40, about 0.35ohms on both negative and positive channel, different from my other 0.21ohm even though they are the same model. Guess not all cema cables are created equal.
https://www.aliexpress.com/item/4000009633191.html
The shallnotbenamed 7N 8 core copper $36, 0.22ohms. Can't say i'm a fan of the chonky wires, chonky connectors, chonky splitter, everything. But I can't question the tough build quality.
https://www.aliexpress.com/item/4000785804947.html
The shallnotbenamed chonky 4 core copper which you can get on XinHS for cheaper. $60. 0.20ohms. I'm not the fan of the weight of this cable. but if you like thick cores, this might be it. Pretty soft for something this thick
https://www.aliexpress.com/item/4001085882852.html
Hmm actually the kz cable I have does not come with a microphone. But I couldn't find a pic with the exact same cable, I corrected the post with more info. I have cheap jcally ones coming in with microphone. We'll see how those hold up.For the extremely high impedance cables the difference clearly lies in the presence of a microphone
I like that thick KZ cable, just wish it came in a variety of connections. Mine also measured low and I remember asking Rikudou about his CEMA measurements also as they weren't very close. Mine is a newer RX.Hmm actually the kz cable I have does not come with a microphone. But I couldn't find a pic with the exact same cable, I corrected the post with more info. I have cheap jcally ones coming in with microphone. We'll see how those hold up.
what a coincidence. I had ordered the blue one XD. They can terminate to QDC if you ask for itFor the third listing (the blue cable), the seller told me the alloy is composed of 97% copper and 3% silver
Yes, the seller is incredibly responsive! I'll look forward to your impressions of themwhat a coincidence. I had ordered the blue one XD. They can terminate to QDC if you ask for it
The Whizzer HE03 would match really well but it isn't one of the IEMs I want rnI really like the look of the blue cable. Been resisting temptation to buy it. Issue I have is that I would have to get a new iem to match it!
Same. Maybe one of the GS audio range in the GD11 shell.The Whizzer HE03 would match really well but it isn't one of the IEMs I want rn
