holsen
I just caught my friend's cat chewing on my new IEM cables
I do not use IEMatch often, but I started to appreciate it more for many points.I actually have had the In Ear Buddy and IEMatch for some time. Never used them much as I thought they affected the sound despite the claims of many that they don't
I'm not sure about this, it has been measured to have the same THD+N ratio with the same power output. It also messes up the frequency response due to the altered impedance. The only advantage I can see is if your device has significant channel imbalance at lower levels on the volume knobI do not use IEMatch often, but I started to appreciate it more for many points.
First, I had an impression similar to yours, but then I realized that the effect on the sound is largely due to the source.
In an ideal world, an ideal source should provide the same instantaneous power, even when a significant part of the power is dissipated by the load.
I never had powerful sources - mine are all portable, but to me the best idea of IEMatch is to be able to use a powerful (actually too powerful for IEMs) source not at its lowest power where signal/noise is high but at its more optimal regime.
In any case, IEMatch is very effective in minimizing the IEM noise/hiss, but when it brings a moderate power source to its upper limits - the distortions can kick in.
Please explain to me how can a resistive load (a resistance bridge) mess up the frequency response other than due to the source limitations?I'm not sure about this, it has been measured to have the same THD+N ratio with the same power output. It also messes up the frequency response due to the altered impedance. The only advantage I can see is if your device has significant channel imbalance at lower levels on the volume knob
https://www.audiodiscourse.com/2019/06/campfire-andromeda-mini-review.htmlPlease explain to me how can a resistive load (a resistance bridge) mess up the frequency response other than due to the source limitations?
Can you give the reference/link to the measurements - first of all for me to understand what was actually measured and how?
Can't say much about the Copper + SPC yet but it has a vivid treble sound signature, not that impressed so far but will try with other earphones.Hi, just showing my latest batch of cables from XINHS.
https://www.aliexpress.com/item/1005001742099286.html?spm=a2g0s.9042311.0.0.77094c4dT0o2H2
Copper Alloy
https://www.aliexpress.com/item/1005001844000119.html?spm=a2g0s.9042311.0.0.77094c4dT0o2H2
Copper + SPC (This one is rosary gold in colour!)
https://www.aliexpress.com/item/1005001874696470.html?spm=2114.12010615.8148356.9.1f513d0e7t5byE
Cheap Copper Alloy
Will post my impression later. Cheers!
Thank you for the links.
I like the look of this one.There are 3 must-buy cable from XINHS so far IMO:
https://www.aliexpress.com/item/1005002036919544.html?spm=2114.12010612.8148356.17.5b0d4cbb5YR2mh
Soft and comfortable, quite lightweight too. Measures as in dimensions or impedance?I like the look of this one.
Anyone knows how it measures, and how comfortable is it?
Resistance, i wounder it's worth it, or is it better to just buy another TRI ThroughMeasures as in dimensions or impedance?
TBH, I have a Degree in Physics and I can tell you as long as the cable is not faulty, resistance actually doesn't matter and to determine the true resistance of the cable you actually need an oscilloscope not a multimeter. And, you can tell I am also an experimentalist as I keep buying cables, lol.Resistance, i wounder it's worth it, or is it better to just buy another TRI Through
Then I guess they dont affect this at all:TBH, I have a Degree in Physics and I can tell you as long as the cable is not faulty, resistance actually doesn't matter and to determine the true resistance of the cable you actually need an oscilloscope not a multimeter. And, you can tell I am also an experimentalist as I keep buying cables, lol.
I posted my little impression here:
https://www.head-fi.org/goto/post?id=16267961
