courierdriver
There you go @paulwasabiiC$ 17.26 29%OFF | 8 Core Silver Plated 2.5/3.5mm/4.4mm Balanced Cable To MMCX 0.78mm 2 Pin Connector Hifi Headphone Upgrade Cable For TRN QDC TFZ
https://a.aliexpress.com/_m0NYwgJ
I am one of those who believe in cable-rolling and I am certain that cables do affect the sound so I actually have bought around 30 cables so far.I noticed this cable too as I was comparing their cables with some branded cables. But I think this is not the same as the FAAEAL copper litz.
I bought the Yin-yoo (censored brand name) 8 core copper the other day and I am quite impressed:
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
This one I am certain it has the same core cable as the FAAEAL.
I bought these:
https://www.aliexpress.com/item/1005001797472128.html?spm=2114.12010612.8148356.41.5b0d4cbb5YR2mh
Gold plated copper - interesting for me as I have silver-plated-copper-gold-plated copper mix and also silver-plated-copper-gold-plated-copper-copper mix
https://www.aliexpress.com/item/1005002036919544.html?spm=2114.12010612.8148356.17.5b0d4cbb5YR2mh
This one is silver-plated copper - I asked the seller they actually listed several cables with the same spec but different price there, they also have one with black skin
https://www.aliexpress.com/item/1005002091739835.html?spm=2114.12010612.8148356.27.5b0d4cbb5YR2mh
This one I think is copper only - should be quite interesting - the colour combination is too ugly and luckily the seller told me I can customize my own colour combo and of coz I order all black.
https://www.aliexpress.com/item/1005001796996285.html?spm=2114.12010612.8148356.31.5b0d4cbb5YR2mh
And I think I will be getting this one. Read somewhere this one is quite expensive elsewhere and they give spacious sounds with smoothed top-end.
That graphene cable is indeed around the same price as on aliexpress. The only one I can recommend from personal experience is the faaeal cable AKA cable A3.Okay, guys. Need some cable advice. So I've got a BQEYZ Summer coming in a few days for review purposes. Ordered the 3.5mm variant in the black/dark violet colorway. As this will be my most expensive pair, I think that investing in a "good" aftermarket cable wouldn't be that bad. Budget is limited to about 30 +- 10 USD. Here's what I'm looking at:
1.) NICEHCK C8s-3 for 14 USD.
2.) Faaeal Hibiscus for 12 USD
3.) NICEHCK C24-2 for 20 USD
4.) KBEAR Expansion for 24 USD
5.) XINHS Graphene Cable for 38 USD (@RikudouGoku , found one for sale on Shopee. Is this about the same price as what you bought?)
6.) TRN T6 for 16 USD
7.) HAKUGEI 4-core Copper for 36 USD
Anyone have experiences with these cables?
And here's a question I really want to ask, even if it has caused much-heated debate for the past few days, "HOW DO THEY SOUND?"
I'm also chasing an "aesthetic" look.
Thanks a lot for any reply and other cable suggestions are much welcome.
The nicehck and kbear 24 are the same cables. I have the FAAEAL like everyone else it actaully came with the spring 2 so the summer should ship with a similar quality cable which you might want to skip. I have the T6 and it is one of the best cable at this price. I also had the 8 core graphene cable but didn't like it. You might refer to my post right above yours and I recommend getting the beige cable which is within your budget.Okay, guys. Need some cable advice. So I've got a BQEYZ Summer coming in a few days for review purposes. Ordered the 3.5mm variant in the black/dark violet colorway. As this will be my most expensive pair, I think that investing in a "good" aftermarket cable wouldn't be that bad. Budget is limited to about 30 +- 10 USD. Here's what I'm looking at:
Thanks a lot! So, considering that the stock BQEYZ cable is of similar quality as the Faaeal's, you just saved me moneyThe nicehck and kbear 24 are the same cables. I have the FAAEAL like everyone else it actaully came with the spring 2 so rhe summer should ship with a similar quality cable which you might want to skip. I have the T6 and it is one of the best cable at this price. I also had the 8 core graphene cable but didn't like it. You might refer to my post right above yours and I recommend getting the beige cable which is within your budget.
Thanks a lot!That graphene cable is indeed around the same price as on aliexpress. The only one I can recommend from personal experience is the faaeal cable AKA cable A3.
Yes, the Spring 2 stock cable is the faaeal cable. But we dont know what cable the summer got though.Thanks a lot! So, considering that the stock BQEYZ cable is of similar quality as the Faaeal's, you just saved me moneyI do have my eyes on the T6 as the "specs" interest me. Might get them for the KS1 or DQ6. I'll try to look for that beige XINHS on Shopee.
Thanks a lot!
Well, from the pics, it looks like it has the same jack, splitter(except cinch or whatever it's called) and connectors but now in an 8-core fashion?Yes, the Spring 2 stock cable is the faaeal cable. But we dont know what cable the summer got though.
It is likely the same cable maker as the core cable of the FAAEAL coppet litz (and also YY 8 core copper litz) which is called Acrolink. I happen to have the 8 core version of the silver plated copper litz (by YY) so I assume the Summer will come with the 4 core version as it looks very similar to mine.Well, from the pics, it looks like it has the same jack, splitter, and connectors but now in an 8-core fashion?
Looks different, but still seems pretty good. Usually I wouldnt recommend spending money on cables when the stock cable is already good.Well, from the pics, it looks like it has the same jack, splitter(except cinch or whatever it's called) and connectors but now in an 8-core fashion?
unless you’ve converted from single ended to balanced.Looks different, but still seems pretty good. Usually I wouldnt recommend spending money on cables when the stock cable is already good.
Much better for you to spend it on getting a big tip collection (if you dont already have it, if so just save money lol).
ok, yeah. Thats the biggest reason I switch cables. Although the Spring 2 had the option to get a stock 4.4mm (or 2.5mm) cable. Not sure if the summer has that option, but that option is quite rare.unless you’ve converted from single ended to balanced.
I could confirm that Summer also has options for a balanced cable. But I ordered 3.5mm cause I have yet to walk the "balanced path."ok, yeah. Thats the biggest reason I switch cables. Although the Spring 2 had the option to get a stock 4.4mm (or 2.5mm) cable. Not sure if the summer has that option, but that option is quite rare.
Then the cable might be good as well. At the very least, I recommend waiting for the Summer to arrive before you decide to spend more.I could confirm that Summer also has options for a balanced cable. But I ordered 3.5mm cause I have yet to walk the "balanced path."
