Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Sep 4, 2020 at 2:09 PM Post #4,846 of 9,533
Anyone know of any cables like the KBear rhyme or nicehk stuff with a decent mic? Actually just any decent/bang for buck cable with a good mic/remote on it would be appreciated.
This mic
https://www.aliexpress.com/item/330...earchweb0_0,searchweb201602_,searchweb201603_
for instance is garbage in my experience if its the same as the one on an mmcx cable from bgvp i have.
KZ pink cable. Very good and comes with mic. Only caveat is that it doesn't come with mmcx pins. Only 2pin connection. Costs $3-4 and also, folks who have measured it have found it to have good stats. Also known as KZ OFC cable.
Sep 4, 2020 at 8:37 PM Post #4,847 of 9,533
Sep 4, 2020 at 10:56 PM Post #4,848 of 9,533
Thanks heaps guys.
I am looking for a 2 pin cable at the moment for some c10's and v90s i have on the way.
Do you have a link? I didn't turn up anything on searching.
Sep 4, 2020 at 11:45 PM Post #4,849 of 9,533
Sep 5, 2020 at 12:01 PM Post #4,850 of 9,533
Sep 6, 2020 at 1:07 PM Post #4,851 of 9,533
Hey guys, what is the difference between the TRN T3 and the T3S?
Seems to be a different 2pin.
Sep 7, 2020 at 10:59 AM Post #4,854 of 9,533
I just had a few TRN-T3 delivered today. I wish I'd read the product page more carefully instead of just looking at the pretty pictures. These cables are 10 cm shorter than customary.
Sep 7, 2020 at 5:45 PM Post #4,855 of 9,533
Oh, yes they are. Sorry I forgot to mention it previously. It has just not been an issue for me thus far.
Sep 8, 2020 at 9:32 AM Post #4,856 of 9,533
(Left = limpid, right = litzps)
Kbear Limpid VS NiceHCK litzps:
Limpid advantage:
Working chin-slider
L/R marked with blue/red colors (very visible)
stronger earhooks
Better looking divider/connector (for me)
Litzps advantage:
a bit cheaper (22.61 vs 23.65 usd)
softer earhooks
I would take the Limpid over the litzps due to the looks and because they both measures around the same, Limpid = 0.46 ohm vs Litzps = 0.53 ohm, most likely unit variation and are exactly the same cable.
(left = rhyme, right = C8)
Kbear Rhyme VS Tripowin C8
Rhyme advantage:
higher quality divider/connectors
red marking for right connector
Lower measurement (0.23 ohm vs 0.34
much cheaper (20.69 vs 29.99 usd)
C8 advantage:
besides the looks, none
The Rhyme makes the C8 100% redundant and a worse cable at a much higher price, not much to say about this comparison other than that. They do look really similar (different colors) but the measurements are a bit lower on the Rhyme so most likely not the same cable.
Sep 8, 2020 at 1:11 PM Post #4,857 of 9,533
just curious, has anyone ever measured the impedance of stock cable of the Blon BL03?
Sep 8, 2020 at 6:51 PM Post #4,858 of 9,533
Other than price, I think there is another key advantage to buying from AliEx during a sale, shipping. My guess is that the total number of orders is a lot bigger after a sale, thus enough items have accumulated for shipments to go out right away. The products I’ve purchased have been shipped within a few days, and within a week, they are at or thru US Customs. The rate limiting step has been domestic shipping.
Sep 8, 2020 at 6:55 PM Post #4,859 of 9,533
Yes, the deliveries from the sale at the end of August were about 1.5 weeks faster for me, too.
Sep 8, 2020 at 8:02 PM Post #4,860 of 9,533
I measured it today (no mic) - 0.7, 0.9, 0.7 Ohm, very similar to (may be a touch above) a typical stock TRN/KZ cable. Blon stock cable has fairly rigid ear guides, so it is quite hard for the fit; while its electrical resistance may not be much of a problem for a single-DD BL-03 with the impedance of 32 Ohm.
