Dsnuts
- Jun 20, 2011
Not the same cable. PM me if you want to know about that cable
I've got one on my TFZ No.3. The Nicehck one.Not the same cable. PM me if you want to know about that cable
Thanks, I've been keeping an eye on it. I have 12 hours left to make a decision. I could get the KBEAR 7N, but did it just go up to $37 from $35?
Kbear is now back to $97 from $37.Glad i ordered one.The NiceHCK C-16-3 is a robust and well-regarded cable, and it's a good price at $21. I have a number of MMCX IEMs it could be used for, including the T4.
between 0.78 and MMCX, which one you used the most? that will be the pick. based on IEM possessions...I'm looking to get one cable for both mmcx and .78mm connector iems, but curious what adapter would be better over the other.
Do you guys think it's better to get an mmcx terminated cable and get mmcx to .78mm adapter (for iems that utilize 2-pin), or .78mm terminated cable with .78mm to mmcx adapter?
Are there better priced adapters than this one. I find this one to be the best one design and functionally. How about alternatives?
Looks like the exact same wire as ISN Audio S4Now enjoying my new EA cable that is rencomend by him.It sound so much details, wider soundstage and bass still rocking.Sound so good in live music.
is not in hazuken list. is in xs series in EA.Looks like the exact same wire as ISN Audio S4
Which number of @hakuzen list is this one?
If same wire then it should be exactly what I think of this wire too excellent value for the price, how much did you bought it?
The wire looks identical to ISN S4 as previously said, but EA is selling it 162$ for the 4 cores version where ISN is asking just 65$ for it ? I'm a bit confusedis not in hazuken list. is in xs series in EA.
is been recommended by EA. So far i really like it it perform better than the 24k EA.
this is a 25awg 49strands per core.Braided is also different.The wire looks identical to ISN S4 as previously said, but EA is selling it 162$ for the 4 cores version where ISN is asking just 65$ for it ? I'm a bit confused
EA pretends the wire is single crystal copper where ISN says its just silver plated. Double confused.. ^^
Do EA begin to lie about its material/wires now? that would be a shame
