new version update:
1, to solve the Pico disk through the XP system after the installation of abnormal problems.
2, repair some PC copy file when there is 0 byte problem.
3, correct some of the state of the battery power broadcast abnormal problems.
4, modify some of the songs play abnormal problems.
I am deciding between a Sony A series (17 maybe) and the Pico. I guess the Pico sounds much better. Though I'd need that implemented English language too...
I recall some rumors that one would be able to control the player from mobile app. It seems that it is not the case? That would be a good use of that bluetooth capability...
2017-08-07: Release the official version 1.1.0.16
The same time as
new version update:
1, optimize the file, folder sorting.
2, optimize the M4A-AAC file format support.
3, optimize the number of individual directory files too much, app-side display file name abnormal problems.
4, the new firmware upgrade:
A) Copy the "pawpico.coe" upgrade file directly to the root directory.
B) After the line is pulled, a "detection upgrade" will be performed.
C) After the success of the green light will be bright, you need to "reboot" to normal use.
Note:
I. Requires 1.1.0.16 and above firmware to have this function,
Ii. Can only be upgraded to a later version
Iii. The original key combination upgrade mode is still available.
Maybe. But I´m quite happy with it. I use it 3 or 4 days a week during my 1 hour running sessions and I don´t miss the previous Ipod nano 7th gen at all, which has 16 GB.
I only use it for sports, so I have in the memory the songs I like most.
What I currently miss is the English voice, since I don´t understand anything that it announces.
via Google Translate: "From the application, you can view and play music files in Pico. If you do not use the application, it will be used like a so-called iPod Shuffle."
Can somebody confirm? Can one actually select tracks from the smartphone app? Got to check it out!
parabellum777: that is really cool. thanks! where did you buy yours? I'm afraid that the Japanese version will only support Japanese (I live in Japan but don't speak Japanese much, haha)
