NJoyzAudio
Thank youAnother way for the Lotoo to "re-sync" the metadata of music files is to wipe system settings, this will obviously wipe any UI/system settings you may have already added but this will help whenever album art takes a long time to show up. You would only have to do this once if you get the issue, in my experience.
Remember that is is more optimal to have the micro sd in exFat format.
Use a good renaming scheme for your music files so that they are played and sorted correctly album to album during playback and navigating. Usually put a "." after the track number and then the track name afterwards.
Resize the album art to 480x480 to match the native screen resolution of the Lotoo.
I have done all of these things as far as ExFat and resizing Album Art.
What I a seeing is when I see a tag that needs adjusting it doesn't show up right away since the file already exists. The Lotoo OS seems to have its own refresh interval before it picks up changes to exiting files
Again Thanks for the info, but have already done these things and taking out the system file vs having the ability to manually resync is a drastic measure IMO
