costas12
- Nov 19, 2010
Is the reason you're not planning on amping them for budget purposes, or is it something else? If you went used I think you would be able to get the DT990 with a suitable amp within your budget.
I would be able to in the US. In the U.K. its hard to find used headphones/amps and they are usually not cheap enough to justify buying them used...
