Socrates
- Oct 3, 2006
Thanks Erik !
[size=x-small]New features and changes in firmware of 7 June 2010[/size]
[size=x-small]The following are the most significant changes. Not all refinements are listed.[/size]
[size=x-small]1. The [/size][size=x-small]ALL [/size][size=x-small]speaker measurement procedure now allows measurements of a speaker or speakers to be[/size]
[size=x-small]made separately in stages. This provides a completely flexible way to create multiple speakers in[/size]
[size=x-small]different locations and with different channel assignments from lesser numbers of real speakers. As a[/size]
[size=x-small]result, a channel on/off screen appears at the end of every measurement sequence to specify which[/size]
[size=x-small]channels are to be saved. For the typical [/size][size=x-small]ALL [/size][size=x-small]procedure, the channels will be set the same as when the[/size]
[size=x-small]measurement sequence began, in which case one additional [/size][size=x-small]OK [/size][size=x-small]keystroke is required.[/size]
[size=x-small]2. Direct mixing of bass (LFE and/or redirected bass) into the headphones is now possible. This is for[/size]
[size=x-small]situations where there is no real subwoofer to be measured, or when there is only an inferior[/size]
[size=x-small]subwoofer, or when the room has modes make low frequency performance problematic.[/size]
[size=x-small]3. The [/size][size=x-small]ONE[/size][size=x-small], [/size][size=x-small]LsRs [/size][size=x-small]and [/size][size=x-small]LbRb [/size][size=x-small]speaker measurement procedures now allow subwoofer (or other)[/size]
[size=x-small]measurements to be added, so 5.1 and 7.1 are now possible in addition to 5.0 and 7.0, etc.[/size]
[size=x-small]4. The [/size][size=x-small]ONE[/size][size=x-small], [/size][size=x-small]LsRs [/size][size=x-small]and [/size][size=x-small]LbRb [/size][size=x-small]speaker measurement procedures now use the default channel[/size]
[size=x-small]assignments.[/size]
[size=x-small]5. Loudspeaker arrays assigned to the same channel can now be created using a single speaker by[/size]
[size=x-small]using an option in the [/size][size=x-small]AVG LOOK C [/size][size=x-small]menu which allows multiple sweeps to run with pauses before[/size]
[size=x-small]each sweep. During the pause, a speaker can be moved to different locations. The typical application[/size]
[size=x-small]is to generate multiple virtual subwoofers from a single real subwoofer.[/size]
[size=x-small]6. Measurement processing has been refined to improve the capture of multiple speaker arrays.[/size]
[size=x-small]7. The [/size][size=x-small]TE [/size][size=x-small]screen is no longer momentary; it remains until [/size][size=x-small]CANCEL [/size][size=x-small]is pressed.[/size]
[size=x-small]8. Manual EQ now uses thirty-one uniform 500 Hz filter bands (except for the last band).[/size]
[size=x-small]9. A [/size][size=x-small]CONTROL MENU [/size][size=x-small]has been added, allowing enable/disable of UART and USB wired remote[/size]
[size=x-small]controllers in addition to the IR remote.[/size]
[size=x-small]10. The [/size][size=x-small]TE [/size][size=x-small]menu has been modified to accommodate wired head trackers.[/size]
[size=x-small]11. For look angle adjustment of “looking centre” after measurement, the left and right speakers’[/size]
[size=x-small]phantom centre image is now used instead of the centre speaker. Thus stereo and other PRIRs which[/size]
[size=x-small]contain no virtual centre speaker can be adjusted; and perceptual sensitivity is increased.[/size]
[size=x-small]12. The HPEQ inverse EQ compression factor ([/size][size=x-small]XFACT[/size][size=x-small]) bands are now [/size][size=x-small]0-5 kHz[/size][size=x-small], [/size][size=x-small]5-10 kHz[/size][size=x-small], and[/size]
[size=x-small]10-24 kHz[/size][size=x-small].[/size]
[size=x-small]13. The head tracker [/size][size=x-small]SCOPE [/size][size=x-small]default is now [/size][size=x-small]HOLD[/size][size=x-small].[/size]
[size=x-small]14. Channel assignment options now appear in SMPTE/default order, and the [/size][size=x-small]C[/size][size=x-small], [/size][size=x-small]LsRs [/size][size=x-small]and [/size][size=x-small]LbRb[/size]
[size=x-small]measurement procedures use SMPTE/default channel assignments.[/size]
Yup, that's my plan.
I had a recorded sample of an SVS Realiser processed stream on my HM-801 and tried it with the JH16 + JH-3A prototype at CanJam, and cranking up the bass was very much like cranking up the LFE channel subwoofer, it was very effective and a lot of fun. It will come in handy a compensating for the vastly different levels of LFE bass in different movies. As you can dial it down for overly bass heavy movies, and cranking it up for bass lean movies, particularly older movies.
-Ed
-Ed
Yes, combined with custom IEM's, it's THE ultimate personally customized music.
Too bad multichannel DVD-Audio and SACD is pretty much kaput.
-Ed
Compared to full-size phones that get measured, wouldn't an IEM present a problem given that it isn't measured and the room measurement assumes that sound is coming from outside the ears not in the canal? Have you found that the overall illusion to be less satisfying in the same way as using generic HTRF's? Or is it just as convincing?
