Does anyone know where i can do the purchase? Looks like their website is not working currently. I can't register.
Little Dot's Current Flagship
- Thread starter rexhu100
- Tags
- flagship little dot tube amp
I think you can checkout littledotus.com or shenzhenaudio, both of them are Little Dot’s official distributorDoes anyone know where i can do the purchase? Looks like their website is not working currently. I can't register.
m-i-c-k-e-y
Posted here since it has been discussed.
So did anybody had a listen to Original OPA-2A 2A3 or OPA-3A 300B amps?
https://destiny-audio.com/products/original-3a-300b-single-ended-tube-amplifier
My Little Dot YD L2 arrives today so leave some impressions in comparison to Woo WA5 LE with Mundorf caps. I'm hoping it is close in sound and can compete with the WA5 LE at a much cheaper price. I do have Woo WA234 being built and that will be my real amp in reality. The YD L2 was a compulsive buy for under 3 grand why not.
So noise is tube issue with 6sh7 so I ordered more because they cheap!
Great sounding amp but needs a soft circuit for turn on. I just wait 10 seconds then plug load in. Sound wise more then good enough to choose this over WA5 LE if you want 300b amp. but the one 6sh7 is causing turn on and continues to buzz on that tube.
lumdicks
- Oct 1, 2013
Got the LD-Y2 to complement with my setup. Got a pair of ACME 274B and 2021 WE 300B and it sounds really amazing with wide soundstage, smooth and forward mid and great dynamics. A pair of WE 717A is on the way to replace the 6SH7, and will try to roll a pair of WE 274B as an all WE combo.
lumdicks
- Oct 1, 2013
Music Nirvana with LD-Y2 and all Western Electric League of tubes (WE274, WE717A and WE300B).
Those look like 274A not B you should mention that so no one screws up listening to the company like I did.
lumdicks
- Oct 1, 2013
One of the rectifiers is 274A with adaptor while the other is 274B which is a matching pair in measurement. I feel sorry for your experience and hope that it can be sorted out soon.Those look like 274A not B you should mention that so no one screws up listening to the company like I did.
Don’t use any other 274 type but western electric. Been told not to use PSvane. So if my power supply went boom due to my eml 274 b don’t use those.
lumdicks
- Oct 1, 2013
I have previously used a pair of Psvane ACME 274B but luckily it worked without problem. I have also used a pair of Mullard GZ33 without issue.Don’t use any other 274 type but western electric. Been told not to use PSvane. So if my power supply went boom due to my eml 274 b don’t use those.
Then there’s a big disconnect in the company not knowing what they are telling me.I have previously used a pair of Psvane ACME 274B but luckily it worked without problem. I have also used a pair of Mullard GZ33 without issue.
Anyone heard the Little Dot LD-Z1 yet? Curious and haven't found much about it.
