Little Dot MKIII Tube Rolling
- Thread starter RogerB
i luvmusic 2
- Aug 27, 2013
If the wires are still long enough for the new POT just solder the harness to the new POT or if the wires become short for the replacement POT then you can clipped short the wires on the connector and solder a longer wires to the connector wires to your new POT.
I also used that stepped attenuator. It brings a substantial improvement, and is probably better than any pot which will fit in the space available. I re-used the original wires, using a decent temperature-controlled soldering iron (carefully, using a fairly high temperature for a very short time, as if working on a headphone driver).
dobigstuff
i luvmusic 2:
Thanks for the help. My wires are now too short and difficult to solder. I contacted Little Dot and they have a replacement Pot.
i luvmusic 2
- Aug 27, 2013
Your welcome!
BTW that is not a real ATTENUATOR it's nothing more than a regular pot with gears so it click.....
This is one of the real attenuators(cheap schiit and it works better than my ALPS BLUE VELVET).
The issue is finding something that will fit in the case! The DACT I have (from Taiwan, if I remember correctly) is a real attenuator, with a "dead spot" between each position. It seems to use SMD resistors though, rather that the full-size TTH components used in the upscale attenuators.
i luvmusic 2
- Aug 27, 2013
I don't think if you can fit a real attenuator on the MK III without hacking or replacing the case not much room to work within the stock case however i manage to install a ALPS BLUE VELVET into my MK III with a good results if you are willing to do it it can be done.PHOTOS ARE FOR REFFERENCE ONLY I'AM NOT RESPONSIBLE TO ANY DAMAGE TO YOUR UNIT.
We should probably all just have started with a Mk IV....
dobigstuff
Scutey:
Getting there. Looking Good. Just waiting for my new Volume Pot
It is killing me not being able to hear these.
Scutey
Scutey:
I feel your pain, just remember though, good things come to those who wait!, and yes it is looking good!
Btw that's an interesting tube combo you have there, dare I ask how does it sound, or is it still waiting to be tried?.
dobigstuff
They are still waiting to be heard.
This is the Tube set up before i damaged the Volume Pot:
Electro-Harmonix 6H30Pi for the Power Tubes. Telefunken 5654 for the Driver Tubes. (These sounded amazing)
Scutey
Electro-Harmonix 6H30Pi for the Power Tubes. Telefunken 5654 for the Driver Tubes. (These sounded amazingI will be interested to
I will be interested to hear what you think of the Telefunkens as I have no experience with them.
dobigstuff
Scutey:
This Tube combo is what I was using:
Yes this combo sounds amazing. I wanted to upgrade the power tubes to the 6SN7. (that's when I damaged the wires to the Volume Pot when removing the Brass Trim rings)
Scutey
Scutey:
The EH is a very good power tube, I have to say I like the 6SN7, I find it a bit more refined/detailed than 6n6 type, not a night and day difference but it's there, must have been a bummer when it was damaged but when it's fixed you'll probably enjoy it all the more!.
I hope you enjoy those 6SN7s!.
Chris Lander
- Mar 3, 2017
Hi everyone,
This is my first post so please go easy on the noob!
So I've just bought a Little Dot Mk II and have several pairs of NOS tubes en-route (6N6P gold grid, Siemens 6AK5W, Voskhod 6ZH1P-EV). The journey has begun and for now i'm stuck with the stock tubes. I've seen a lot of talk of a "Siemens Blue Glass 6AK5W" but none of the sellers i've spoken to have heard of such a thing, only the regular Siemens 6AK5W. Can someone help enlighten me?
Thanks!
Thanks!
