Found another one which is a lot less money for me as it's within EU.
I didn't read the Swedish review!
It does look good quality from what you can tell from his information, I think I would go for one of these though for £160, £10 more, they are OCC silver and have good recommendations. They are 26awg:
[url=http://www.toxic-cables.co.uk/index.php?route=product/product&path=59_61&product_id=59]http://www.toxic-cables.co.uk/index.php?route=product/product&path=59_61&product_id=59
Not really bothered for my HE-500 which sounds good with copper but for the LCD-3 I think silver would be great!
Edit: the UK cost of the Ebay silver cable you posted the link to is £149, I expect it woud be considerably cheaper in Sweden! So the Toxic cables silver cable would probably be quite expensive in comparison but it was only £10 more in UK money, (£160).
The problems with the toxic cable are:
1- "The
total wire diameter is 26awg(thin!)
2- It is silver mixed with
Gold...
This make it either a plated or impure mixed metal.
This results in EVEN LESS silver content for its thin guage.(!)..
Add to this that Gold is noticably
lower and
below copper in
conductivity,
Making this actually a poor choice for us.
It may sound "nice", but most likely
will sound "different".
The following is my sudjective opinions from my own experience:
With the limited amount of silver, the larger signal demands will force electrons to go thru the less conductive gold,
which can cause sonic anomalies, like skew the sonic image...
I have noted this anomaly when using silver plated copper, yet this is different.
This either gold plated or mixed silver.. or both.
For sure this will cause a sonic difference, as the guage is so thin.
For me, the safest approach for choosing a headphone cable,
(Which is a long journey of signal to your headohines) is NOT to mix and mingle strands of different plated or impure metals..
That eliminates alot of cables out there..
Go either all way OCC copper,
Or all silver. ..
To me, that is the Safest choice for retaining proper sonic perspective of ambient cues without ear fatigue.
Last point, none of this will matter as much if your headphones is not a top-tier resolving one.
It will also not matter much if you didn't "supermod" your amp.
Herr is my amp getting last listening done before I open and install new caps and new impedance mod...
Yet even NOW...
The utter lack of any veil, extreme clarity and palpable holographic soundstage is what you get with these mods in place.
I keep having the dilemma that what I hear cannot be described properly without sounding exaggerated...
