What are those coupling caps? Did they come stock with your amp?
Probably didn't need all those pics but better safe than sorry!
No they're Ansars recommended to me by my tech man when I couldn't fit the Audyns I bought because of their size. The idea was to see if I could tell the difference with a cap of a higher capacitance. I since bought the S/O Mundorfs to put in in their place before the mods thread started. He actually put in some posts to the PCB so that there would be no need to remove it again for changing the caps, some hope now that the main mods are about to be done!!!!
BTW Maxx don't forget the HE-500's at 38 ohms, I see you have several cans at around that figure anyway.
And would you say that low impedance cans respond less well to amplification than high impedance ones?
Hello, I didn't know that your copper caps were only 22uf, so although you input may not gp down to 5hz (lol) .22 should stilll get you in the 20hz region.
Main thing is that you will have a great signature, as I verified when I had the copper type cap as main coupling, and the Mundorf as WCF.
Now don't get carried away, as your board is one of the better made boards before they cut costs,
because your small installed resistors are great quality Dale types.
So all your parts are excellent.
I would also almost insist on Cardas Solder.
It will save you headaches.
Also listen to MisterX suggestion with the solid wire, by installing on board first, and soldering onto plugs last.
I WROTE inside my amp with a black marker, where every wire goes.
As for your question, impedance of headphone will be closely matched with the amps output circuit,
So the common story of headphones impedance matching issues with amplifiers,
Will be irrelevant here.
This next mod will be an addition of resistors to the Anode/Plate resistors.
Yet you will not have to pull board out,
As the design of this board places the Anode/Plate resistors on the component side.
