Few questions regarding the coming mod.
Does the modifictaion to be somehow connected with the Lo-Hi gain switch? Will it be still possible to switch between the two modes?
If I will match the amp with my primary headphones 35 ohm (no switch) how it will influence the sound of my secondary once with 70 ohm resistance. They are quite close.
I am wondering for which range of resistance the MKVI was better optimised. Now it can work with 25 ohm and 600 ohm as well doing good job. But there should be a range in which it works more or less optimal. Do you now what is the range value? Just curious as I hope very soon I will optimise the amp for not only the range but for accurate value
, thanks to you guys. I know that I will use the secondary headphones very rarely and for now I don't see any competiton for my primary headphones (including the hd800 new and old). Somehow I don't want to have choices
. I just want to listen to my music. Having many options with tube rolling is more than I wish for as the MK VI with some adapters has endless combination of them. From my point of view the resistor switch will be more suitable for the tube rolling capability of MK VI than for changing the headphones. Having the matching for the different types of tubes eg. 6080, 421A and 5998 families will be a good thing. If you will post an instructions for the mod can you also show us one example of equation with values in it corresponding to the data sheet of the tube eg. 6080 ? I think I can figure it out by my self but good example is always a help.
One more thing. I am testing the russian tubes. They are a 6SL7 family and seems to better the new production Tung Sols. There is not a big difference. In general they are giving more expressive sound.
In my opinion the 6SL7 tube family is more suitable for headphones with low sensitivity (less then 98 db).
