- Oct 14, 2013
Yeah, Cayin knows their stuff well
I wonder if it is deliberately to get a certain sound signature?Yet the Cathode cap is another story.
I always see wide range of values.
Just the other day I worked on a Cayin HA-300, and it has only 100uf(!):
You're probably right, different makers favour different parts choices, and I think it was Cayin that used pure silver internal wiring also? Yet LD make do with tin wire... yuckI regard Cayin the absolute best, at making euphoric sounding amps, without the harshness of unwanted harmonics.
They are genius, when you observe their parts choices...
While I regard Little Dot path, is to use more of "design choices", rather than parts choices, for their sound. Just looking at the bias points of the driver stage, is a prime example.
Yes internally. I can't remember if it was actually them TBH, but one of those Chinese makers, may have been Yamamoto.I would use pure silver wiring where I can, but they are not cheap, and not all silvers are made the same. What Cayin is using pure silver internally ?
@CopperFox uses 100uF Wimas there, (decoupling). Also for driver stage decoupling but I think my 40uF are adequate there.We need to focus on the output stage caps.
The cathode cap is still before the WCF stage.... So any drain would be from those tubes only, not the headphones load, hmmm
Maybe, we haven't touched those!Ok, so on first page, according to Ridge78, half the current of the WCF push/pull design, comes from the cathode caps(!).
So now, what about the WCF cap between the triods? Have we been overlooking these?
Also he uses 400uF PSU film caps which could be good there, I haven't decided.Maybe, we haven't touched those!
Actually we did. I believe you used mundorf thereMaybe, we haven't touched those!
I know and it's no fun reading up on all that any moreIt sucks that all the original pics are gone from first page. I have most but it will take time to find and re-upload.
Sorry for the momentary lapse.. for some reason I was thinking of those original small Wimas that were there before we replaced them. I did use Mundorf and I only realized recently that they were film caps, polypropylene metallized with silver as opposed the the MKP Mundorfs we used for decoupling which were polypropylene metallized with aluminium.Actually we did. I believe you used mundorf there.
I don't like to admit it but you must be right, the WCF being just as important as the cathode caps, my problem is I don't really understand the maths behind the WCF.Actually we did. I believe you used mundorf there.
My issue is I am wondering about current drain, as caps used as output caps are large (for current), and not have anything to do with frequency, so although as only 220uf was needed here (stock) for frequency....
I'm wondering if more capacitance would help here with transients...
Because the cap is in series with output flow, just like an output cap...
