As I've lived with the recent changes for a while now I just thought I would summarize where I'm at with the last mods which have been tested against the other amp as a control, because I think it would be interesting to discuss. We've all pushed this baby quite a way from stock... travelled to distant galaxies to seek out new life and new civilisations... and all that.
I highly recommend the last 3 mods: CCS with improved operating point over stock, OCC silver output wires, and the Nichicon Muse KZ cathode caps. This has brought the sound up to a very high level. The CCS has made the sound a touch cleaner, and more lively with the revised operating point, the silver wires made the sound brighter and more transparent, and the Nichicon caps made it sharper and more extended. The combination of the silver wires and the Nichicon caps on the high frequencies has brought the high hats and cymbals into the foreground now whereas before they were very much in the background which is a very positive improvement I think. To compare the 2 amps, my APPJ, and the LD, they now sound very similar, due to the mods, in a good way.
For anyone thinking of doing this the APPJ cost virtually nothing, as amps go, but the cost was doubled with the mods. Both amps now are very highly resolved, the APPJ with the 14AF7 tubes, and upgraded caps has been pushed to a high level. The 14AF7 cost a few dollars, the EL84 Amperex tubes are not expensive. For the LD the Nichicon caps are cheap, the CCS was pretty cheap, the OCC silver wire was a bit more expensive but not much was needed. The LD uses RCA 6AS7G tubes which are cheap, and 12SL7 GE's which cost a few dollars. I see now that the 6SL7 GE's have the same silver round plate construction and so would be preferred because they don't need adapters obviously, but I already had the 12SL7's from the APPJ.
To sum up the sound signature, both amps are very resolved, have good soundstage, good rich open sounding mids, tight bass and extended treble with good textural details. The sound is neutral to warm sounding, I would suggest if you wanted a warmer sound to use OCC copper wires instead of OCC silver, this will make it slightly smoother and less incisive sounding. With the OCC silver the sound is more transparent and sharper.
Needless to say both amps sound fantastic! The amps do have slight differences but nothing major. I wanted to increase the resolution and soundstage of the APPJ and for the LD I wanted to get it to sound more dynamic and lively with a heightened treble and tighter bass and I think I've finally managed to lick the problem! It's a tad brigher and sharper, but not harsh, especially in the high frequencies which is the main reason for the improvement, and transients are very lively. Having the 2 amps was good for comparison especially as the APPJ is a speaker amp.
