I've desoldered the switch and am trying to figure it out.
Below are the connections to the switch which is ON-OFF.
My values for high gain for the 390K and 68K resistors are 27K and 68K, the values for low gain are 10K and 10K.
My problem is seeing how these values are arrived at from the connections below, can anybody see how to arrive at the above values which I believe are correct because they are the same for 3 of the 4 circuits, wheras the values for the 4th circuit are 37K and 68K!!!
There is also resistance in the switch position but it must be built into the board because I measured 100K from the 2 points on the board with the switch out.
I believe my problem with the 390K resistor reading is due to the switch not fully opening or closing properly, but until I know how to arrive at the correct values I can't bypass the switch with fixed resistors.
I'm just having trouble seeing what is in parallel to what here!
However I think with the switch out the connections are configured to high gain because on low gain the switch is on and without the switch in place it would be off.
