Any way to test if there was damage to the transistors?
Here's how you test transistors on a DMM:
Step 1: (Base to Emitter)
Hook the positive lead from the multimeter to the to the BASE (B) of the transistor. Hook the negative meter lead to the EMITTER (E) of the transistor. For an good NPN transistor, the meter should show a voltage drop between 0.45V and 0.9V. If you are testing PNP transistor, you should see “OL” (Over Limit).
Step 2: (Base to Collector)
Keep the postitive lead on the BASE (B) and place the negative lead to the COLLECTOR (C).
For an good NPN transistor, the meter should show a voltage drop between 0.45V and 0.9V. If you are testing PNP transistor, you should see "OL" (Over Limit).
Step 3: (Emitter to Base)
Hook the positive lead from the multimeter to the to the EMITTER (E) of the transistor. Hook the negative meter lead to the BASE (B) of the transistor.
For an good NPN transistor, you should see “OL” (Over Limit).If you are testing PNP transistor, the meter should show a voltage drop between 0.45V and 0.9V.
Step 4: (Collector to Base)
Hook the positive lead from the multimeter to the to the COLLECTOR (C) of the transistor. Hook the negative meter lead to the BASE (B) of the transistor.
Step 5: (Collector to Emitter)
Hook the postitive meter lead to the COLLECTOR (C) and the negative meter lead to the EMITTER (E) – A good NPN or PNP transistor will read "OL"/Over Limit on the meter. Swap the leads (Positive to Emitter and Negative to Collector) – Once again, a good NPN or PNP transistor should read “OL”.
If your bipolar transistor measures contrary to these steps, consider it to be bad.
Also do you have a link to where you got the 3w Zeners from ? Im ordering the transistors from mouser..
Just use any 2 or 3w 100 V zeners, nothing special. Would also recommend higher wattage resistors for the 2k2 and 2k7. Mills MRA5 is a tight fit in those holes. Here's mine.
