baronbeehive
Are you saying there is continuity between 6 and ground? How are you measuring ground?
Yes, there are 2 separate things:
1 - continuity with ground with each of pins 3, 5 and 6 ie. each is grounded
2 - continuity between pins 3, 5 and 6 in whatever order ie each is connected with each of the others
I'm measuring ground by putting one probe in a screw hole in the chassis, or when the board is in, by putting it in a screw hole or in one of the 2 big holes near the PSU caps. The other probe touching the tube pins in turn.
BTW coin, I'm going out tomorrow to get the opamp extractor tool.
BTW Maxx, the engineer said that he didn't like all of the bunch of wires going in the small hole to the transformer, very tight fit and the hole has sharp edge.
