coinmaster
I still don't see what you're talking about there's no -ive label nor do I see any XLR exits.
Today is a glorious day, I finally purchased another MK6 lol. I turned off my brain and just clicked the buy button before logic and reason returned to me
Also the fact that I'm constantly waiting on parts made me realize that my prototypes will never be a good way to just listen, at least not anytime soon. Dear god help my bank account.
What have you been using for music listening then? At least I've got my speaker amp.
Inside right hand (bad) circuit : cathode bypass/resistor, coupling cap, WCF, anode resistor connections.
Inside right hand (bad) circuit : -ive output connection.
Both right hand circuits : cathode bypass/resistor connections.
Both right hand circuits : heater wire connections.
Outside right hand circuit : cathode bypass/resistor, WCF, coupling cap, connections.
Outside right circuit : anode resistor connections.
Nothing
Also I take it back again, I was going off the top of my head before, 3 and 5 should be connected not 5 and 6 so if 5 and 6 are connected then you got probs. Remove tube and test again and check backside of board.
6 shouldn't be grounded. The only thing that should be connected to 6 is the cathode resistor and bypass cap.
Did you change the wiring to the rear pre-amp out sockets at all?
Is there any possibility it could arise from that?
(Yes, I am in preparation for modding. I am still putting together a parts list.)
Have you done anything with the volume pot?
it shows continuity with the cathode bypass and resistor but is grounded. I've looked at the tube sockets and there doesn't seem to be any way that there could be a short between pins 5 and 6 so it must be somewhere else in the circuit. I keep on checking the wiring, connections etc. and can't see anything relevant at all.
Are you saying there is continuity between 6 and ground? How are you measuring ground?
