Is it the one you pictured?
how many tubes and what are they?
The past picture shows a straight line of tubes..
Just curious to know the layout
Since you asked, I'll answer despite off topic!
The pictured one was my flagship amp. Forced balanced from input to output.
The two rightmost tubes are input stages; 6SN7 russian eq.
The four left side tubes are 4P1L, each grid driven by a source follower buffer.
The power buffer on top is 4 source followers with CCS loads driving parafeed OT's. Each follower has about 15mA bias current.
It has 4 PSU:s, each regulated with a simple 2 FET regulator;
1) +290V for the input stage and the grid buffers
2) +356V for the output tubes
3) +305V for the power buffer
4) -14V for the input stage tails.
The signal parts have 28 FETs, the regs have 8. Also 4 low rdson FETs regulate each of the 4P1L filament supplies. The amp has a pitch black background despite having DH tubes (not a given by any means).
My current (not in any casing, just breadboard) workhorse amp is similar topology. 12AX7 input stage, grid buffers feeding 6E5P output tubes. Single B+ of 310V with a two FET reg, no output buffer.
This one has some problems, some background noise. The super high transconductanse tubes such as 6S45P and 6E5P can be a pain to deal with. They do provide excellent dynamics though, even without a FET power output buffer. Not as good, but pretty great.
Anyway it has good sound quality, so I'm too lazy to work on it. I'll build another amp for myself later, identical to the flagship amp I made earlier. I already have the chassis worked and painted and also most of the woodwork done.
I've made a number of variations on the theme with different tubes. Next I'll make a fully forced balanced 6SL7 -> grid buffer -> 2C22 -> power buffer, for one person I know.
2C22 is in my experience the most linear and sturdy 6SN7 variant there is. It should be, since it was made to be just that.
The amp I'm thinking about sending out to the gentleman in Denmark and possibly further on from there would be fully forced balanced 6SL7 -> grid buffer -> 6SN7 -> very small power buffer, kind of a stripped version of the previous model. I must make it yet smaller or it's not going to be possible...
